melted candle wax in drain pipes
Discussion in 'Home Repair' started by dee, Aug 5, 2006.
  1. dee
    dee Guest
    A candle melted and leaked down into my washing machine. I thought
    that I had it all removed but when I washed a load of clothes, the
    draining water backed up into my tub and bathroom sink. There was red
    candle wax all over the place. Needless to say now my bathroom and
    washing machine drain pipes are stopped up. I've used 2 bottles of
    sulfuric acid and this hasn't helped. Can anyone please tell me how to
    dissolve the wax that is down in the pipes or please tell me how to fix
    this problem.
    dee, Aug 5, 2006
  2. Is there a "P" or "S" trap down stream from your washing machine? If so you
    may have been lucky enough to have "traped" the wax in it. If so,
    disassembly and cleaning may be easy. Good luck.
    "dee" <> wrote in message
    > this problem.
    > Thanks
    John Lawrence, Aug 5, 2006
  3. dee
    Speedy Jim Guest
    > this problem.
    > Thanks
    For real?
    Chances are that the wax particles (solids, not liquid)
    combined with the usual hair/soap mess found in drains
    and delivered the final blow to what was already nearly
    clogged.
    My vote in this situation would be for a drain cleaning
    machine. You *might* get away with a canister type
    which fits on a drill or is hand-powered, but I doubt it.
    After that, it means a professional-size auger.
    If you're a determined DIY'er, the machine can be rented.
    Jim
    Speedy Jim, Aug 5, 2006
    >this problem.
    >Thanks
    Sounds trollish.
    tom
    Tom The Great, Aug 5, 2006
  5. dee
    EXT Guest
    "Tom The Great" <> wrote in message
    >>this problem.
    >>Thanks
    > Sounds trollish.
    Yes, how did a candle melt and leak down into a washing machine, then how
    did the melted wax get from the washing machine into the drain? At some
    point it would have solidified in place long before it got into a drain.
    EXT, Aug 5, 2006
  6. dee
    glenn P Guest
    Completely troll - what a life...
    >>this problem.
    >>Thanks
    > Sounds trollish.
    > tom
    glenn P, Aug 6, 2006
  7. dee
    Guest
    On Sat, 5 Aug 2006 17:13:53 -0400, "EXT" <>
    >news:...
    >>>this problem.
    >>>Thanks
    >> Sounds trollish.
    I was thinking the same thing. Of course people do some really stupid
    things at times, and this is one of the more stupid I have heard. If
    it dripped in the machine it would have solidified upon hitting the
    tub bottom, and scraping it out would be required. Aside from a few
    loose particles during removal, none should have gotten in the drain
    pipes, unless the guy scraped it loose and expected the machine to
    "eat" the scrapings. It could be a coincidense that the drain plugged
    at the same time too.
    I could be nasty and suggest burning the house down. The heat would
    melt the wax......
    But I'll be nice tonite. A hand snake or power auger is probably the
    only solution. If this is on a septic tank, the tank could be plugged
    too, or a sewer line is clogged.
    If other fixtures work in the house, then the clog is probably local
    to that machine and surrrounding fixtures.
    , Aug 6, 2006
  1. macson
    441
    macson
    Mar 22, 2006
  2. I-zheet M'drurz
    Wax down the drain -- results???
    I-zheet M'drurz, Dec 8, 2003, in forum: Home Repair
    220
    I-zheet M'drurz
    Dec 8, 2003
  3. Bob
    Removing candle wax from carpet
    Bob, May 10, 2004, in forum: Home Repair
    276
    Charlie Bress
    May 10, 2004
  4. leonard hofstadter
    Wax On, Wax Off
    leonard hofstadter, Sep 29, 2011, in forum: Home Repair
    533
    Bob(but not THAT Bob)
    Oct 1, 2011
  5. oldyork90
    492
    oldyork90
    Dec 7, 2012
