Low water level in toilet
Discussion in 'Misc DIY' started by Lawrie, Jan 30, 2007.
  1. Lawrie
    Lawrie Guest
    I have a washing machine and a sink in the garage; the washing machine
    drains into what I think is called a spigot on the drain pipe from the sink
    then the pipe goes through the garage wall into the downstairs toilet. The
    toilet outflow has a special sort of adapter behind the u-bend with a sealed
    hole in the top into which the pipe from the garage goes.
    This has worked OK since we moved in but suddenly now when the washing
    machine is emptying, air bubbles seem to be gurgling up in the toilet and,
    more importantly, the water level in the toilet seems to end up very low. In
    fact it seems to be lower than the bottom of the pipe beyond the u-bend
    going into the adapter.
    I thought the u-bend was supposed to keep the water level in the toilet at
    the correct level; I am puzzled as to how it can end up lower than this.
    Both the washing machine and the toilet seem to be emptying OK, but with
    this gurgling and very low water level. Has anybody any ideas.
    Thanks, Lawrie
  2. Lawrie
    Guest Guest
    On 30 Jan,
    "Lawrie" <> wrote:
    > Hi,
    > sealed hole in the top into which the pipe from the garage goes.
    > In fact it seems to be lower than the bottom of the pipe beyond the u-bend
    You've got a (probably partial) blockage downstream. It needs clearing before
    it gets worse.
    B Thumbs
    Change lycos to yahoo to reply
    Guest, Jan 31, 2007
  3. Lawrie
    Guest
    On 31 Jan, 00:08, <> wrote:
    > On 30 Jan,
    > "Lawrie" <> wrote:
    > > Hi,
    > it gets worse.
    yes, you'll quickly have a complete block.
    NT
    , Jan 31, 2007
  4. wrote:
    > On 30 Jan,
    > "Lawrie" <> wrote:
    >> Hi,
    > it gets worse.
    Agreed. Something like that. Flow is no longer smooth..
    Start of tipping a pint of caustic soda crystals down the bog.
    Flush once, then three kettles of boiling water and leave.
    Use gloves and spectacles and mop up splashes with lots of cold water.
    That usually clears soapy/fatty/ scummy stuff. Which is the glue that
    binds the tissue and cloth items together..
    The Natural Philosopher, Jan 31, 2007
  5. Lawrie
    robgraham Guest
    On 31 Jan, 01:43, The Natural Philosopher <> wrote:
    > wrote:
    > > On 30 Jan,
    > > "Lawrie" <> wrote:
    > >> Hi,
    > > it gets worse.
    I've a drainage system that did block **totally** recently, to the
    extent that I had to dig because it is an old porcelain drain and
    there's no surface access, so this thread interested me. Fortunately
    the dig was shallow and I got access through the lid of a bend, but I
    don't want it to happen again - and yes the washing machine and toilet
    are on that branch.
    Two questions:- I didn't know about caustic soda crystals; are they
    available at the sheds etc ? And secondly can I use this as a cure
    when the whole lot tips into a septic tank ?
    Rob
    robgraham, Jan 31, 2007
  6. Lawrie
    Pete Cross Guest
    Surely if the water level in the bowl is dropping then it points to the soil
    stack not getting any air in at the top ? ie it is now sucking air through
    the bowl and taking the water with it ? jammed air admitance valve ?
    Pete
    Pete Cross, Jan 31, 2007
  7. Lawrie
    Jethro Guest
    On 30 Jan, 23:51, "Lawrie" <> wrote:
    > Hi,
    > Thanks, Lawrie
    This sounds similar to something I experienced when I first moved into
    my house. I didn't get the bubbling, but the water level in the pan
    would be very low occasionally.
    In teh end some asked if it was windy when it happened, and I realised
    it was. Basically the wind was causing a venturi over my soil stack
    which was enough to siphon some water into the sewer.
    Not really sure how to deal with it ... the water level has never
    fallen so low as to break the air/water barrier.
    Jethro, Jan 31, 2007
  1. j
    j, Oct 25, 2003, in forum: Misc DIY
    287
    Jason
    Oct 27, 2003
  2. Replies:
    1,285
  3. taffy
    352
    Speedy Jim
    Jul 16, 2006
  4. Mitch
    443
    Jeff Wisnia
    Feb 16, 2007
  5. KOS
    17
    558
    Harry K
    May 13, 2010
