Looking for jackable wheelstands for car
Discussion in 'UK DIY' started by MM, Jul 16, 2011.
  1. MM
    MM Guest
    I don't fancy driving the car onto fixed wheelstands so I wondered if
    there are scissor types available where you drive the car over them,
    then jack them up and insert a safety bolt or something. Any ideas
    what to Google for? I tried a few terms, but Google just floods me
    with everything under the sun (as per usual).
    By the way, I only need these for the back of the car. (Yes, I know I
    could jack the car up normally, then put axle stands underneath, but
    modern cars often don't have anywhere safe to place the stands, hence
    wheelstands should be safer.)
    MM
    MM, Jul 16, 2011
  2. Newshound
    Newshound Guest
    > MM
    Ramps are OK. If you are nervous, get a pair of the longer shallow angle
    ones intended for sports cars. That said, a proper garage lift is on my
    lottery list, together with the swimming pool...
    Newshound, Jul 16, 2011
  3. Steve Firth
    Steve Firth Guest
    You still seem to be running away from answering the question of how
    manyu children you have brought up. Surely an expert on childcare would
    remember how many children they have?
    Steve Firth, Jul 17, 2011
  4. Alan
    Alan Guest
    In message <>, Trigger
    <> wrote
    >http://www.car-lift-cn.com/car-scissor-lift.html
    Even someone without engineering knowledge can see that the legs will be
    the first bit to collapse on that design, especially as a medium size
    car is circa 1200 Kg and the car lift is rated at 350Kg (static load?)
    It's not something that I would use to work UNDER a car.
    Alan
    news2009 {at} admac {dot} myzen {dot} co {dot} uk
    Alan, Jul 17, 2011
  5. Bob Minchin
    Bob Minchin Guest
    FFS give it rest Firth!
    Bob Minchin, Jul 17, 2011
  6. Steve Walker
    Steve Walker Guest
    By the length and width, you'd be using two or four of these at a time.
    Four at a time and each will be seeing only 1/4 of the total weight -
    ignoring any weight differential between front and rear of the vehicle.
    Two at a time, and it'll probably less, as lifting one end (or even one
    side) of the car will transfer weight to the grounded end/side.
    No. I'd not want to use them either, they just don't look right do they?
    Although they are presumably designed and tested to well over the rated
    load.
    SteveW
    Steve Walker, Jul 17, 2011
    But each wheel won't have 1200kg on it just a fraction but I agree
    the legs do look like bits of pressed steel. It will also need a
    smooth surface for the legs to rest on as they will need to come
    together as the lift rises and it appears to be pneumatic rather than
    hydraulic.
    Cheers
    Dave.
    Dave Liquorice, Jul 17, 2011
  8. Huge
    Huge Guest
    > lottery list,
    Have a look on eBay - they aren't that expensive. The real pain is that they
    usually have 3 phase motors.
    Today is Pungenday, the 52nd day of Confusion in the YOLD 3177
    Sing, for song drives away the wolves.
    Huge, Jul 17, 2011
  9. In article <>,
    Well, you're still going to have to drive onto those - so what's the
    difference? They'd also by nature be heavier than a fixed type - and
    decent fixed types are already quite heavy/bulky. If you don't like
    driving up the steep slope, ones with a more gradual one can be found.
    If the problem is the car pushing them along, fix some rubber matting to
    the bottom.
    Generally anywhere near a suspension mount will be strong enough to take
    the weight. Use some decent wood to protect things.
    *If you think this van is dirty, you should try having sex with the driver*
    Dave Plowman London SW
    Dave Plowman (News), Jul 17, 2011
  10. Adrian C
    Adrian C Guest
    Visions of a car parked and floating haphazardly (air beds?) in the
    middle of a swimming pool have swum into my head, dunno why...
    Ah, has me alarm clock gone off yet?
    Adrian C
    Adrian C, Jul 17, 2011
  11. Alan pretended :
    > Even someone without engineering knowledge can see that the legs will be the
    > first bit to collapse on that design, especially as a medium size car is
    I think that lift, is intended to be a motorbike lift. It only shows
    one, which would just lift one side of a car.
    Regards,
    Harry (M1BYT) (L)
    http://www.ukradioamateur.co.uk
    Harry Bloomfield, Jul 17, 2011
    #11
  12. Alan
    Alan Guest
    In message <>, Harry
    And that's why its described as a car scissor lift :)
    Alan
    Alan, Jul 17, 2011
    #12
  13. Guest
    On Sun, 17 Jul 2011 10:37:54 +0100, "Dave Plowman (News)"
    <> wrote:
    >In article <>,
    >difference?
    Sods law could kick in as well, When you find the job you need to do
    is easier or requires the wheels/hubs etc off then you still have to
    support elsewhere anyway.
    G.Harman
    , Jul 17, 2011
    #13
  14. Andy Dingley
    Andy Dingley Guest
    I generally winch mine up with a horizontal cable winch or Tirfor,
    rather than driving up. It's slower, easier to control, and certainly
    much easier if you're working on your own.
    Andy Dingley, Jul 17, 2011
    #14
  15. It happens that Alan formulated :
    Well it is a Chinese web site and we all know what Chinese instruction
    leaflets are like, when translated lol
    Regards,
    Harry (M1BYT) (L)
    #15
  16. Steve Firth
    Steve Firth Guest
    FFuck off!
    #16
  17. Trigger was thinking very hard :
    > "Harry Bloomfield" <> wrote in message
    > news:...
    > I don't like the Chinese; not after what they done to Pearl Harbour.
    I think that may have been the Japanese.
    Regards,
    Harry (M1BYT) (L)
    #17
  18. MM
    MM Guest
    On Sat, 16 Jul 2011 22:23:00 +0100, Newshound
    >> MM
    In a previous house I had the luxury of a pit. Does one need planning
    permission to dig one in the garage? Would it upset the 'balance' of
    the house foundations?
    MM
    MM, Jul 17, 2011
    #18
  19. MM
    MM Guest
    MM, Jul 17, 2011
    #19
  20. Newshound
    Newshound Guest
    >>> MM
    > MM
    A mate of mine dug one, years ago, and three of us spent a lot of time
    in there. This was a garage at the bottom of the garden (1970 estate in
    Yate) so well away from house footings. The biggest single problem was
    the amount of ground water which seeped in. He subsequently lined it
    with some sort of rubber tanking compound which kept a lot of it out,
    but we still needed to pump out the sump every time we used it.
    Newshound, Jul 17, 2011
    #20
  1. Phil
    51
    2,565
  2. Ricky C
    909
    Dave Liquorice
    Feb 15, 2005
  3. Christopher Chance Knight
    Looking for to break in. / Student looking for work
    Christopher Chance Knight, Oct 13, 2008, in forum: HVAC
    385
    Guest
    Oct 16, 2008
  4. newshound
    21
    483
    Grimly Curmudgeon
    Nov 26, 2010
  5. Murmansk
    18
    302
    John Williamson
    Nov 13, 2012
Share This Page
