Leaking sink waste connection ?
Discussion in 'UK DIY' started by Tonyb, Jan 6, 2010.
  1. Tonyb
    Tonyb Guest
    I have just fitted a new sink in my cloakroom which has one of these
    click/clack waste fittings, with the overflow running into the slotted waste
    fitting The plug fitting drops through the hole in the sink, with a plastic
    washer between the plug and sink, with another plastic washer/seal that fits
    under the sink with a large nut to tighten the plug to sink joint. My
    problem is I cannot tighten the nut enough to prevent water running down the
    thread of the waste fitting below the sink. I'm guessing that the water is
    finding a route either between the plug and sink on the top side, or
    possibly through the lower washer ? Is there a better way of sealing this ?
    Tony
    Tonyb, Jan 6, 2010
    > slotted waste fitting The plug fitting drops through the hole in the
    > sink, with a plastic washer between the plug and sink, with another
    > plastic washer/seal that fits under the sink with a large nut to
    > tighten the plug to sink joint. My problem is I cannot tighten the
    > nut enough to prevent water running down the thread of the waste
    > fitting below the sink. I'm guessing that the water is finding a
    > route either between the plug and sink on the top side, or possibly
    Buy a tube of Fernox LS-X, apply thinly to all mating surfaces, leave for an
    hour.
    Dave - The Medway Handyman
    www.medwayhandyman.co.uk
    The Medway Handyman, Jan 6, 2010
  3. On Wed, 6 Jan 2010 15:46:57 -0000, "Tonyb" <>
    >Thanks
    >Tony
    click/clack ..I presume you mean a popup waste .
    I have one of those and had no problem with any leakage but I think I
    dumped the upper washer and used Plumbers Mait to seat it .. As for
    the large nut underneath I have just had a quick look using a mirror
    and there is a washer underneath but I have a feeling it is rubber not
    plastic .I think I might have smeared it with LSX sealant and
    certainly I have had absolutely no problem with it since it was
    fitted. Are both the washers you got with the waste plastic ?...is one
    not rubber .
    Usenet Nutter, Jan 6, 2010
  4. Tonyb
    John Guest
    "Usenet Nutter" <> wrote in message
    >>waste
    >>plastic
    >>fits
    >>the
    >>Thanks
    >>Tony
    > not rubber .
    Concentrate on sealing behind the nut.
    John, Jan 6, 2010
  5. Tonyb
    TonyB Guest
    >>waste
    >>plastic
    >>fits
    >>the
    >>Thanks
    >>Tony
    > not rubber .
    The lower one is rubber.
    So the general consensus seems to be to use fernox lsx sealant/plumbers mait
    and possibly not use the upper plastic washer either ?
    TonyB, Jan 7, 2010
  6. Tonyb
    NT Guest
    > news:...
    > >>waste
    > >>plastic
    > >>fits
    > >>the
    > >>thread of the waste fitting below the sink. I'm guessing that the wateris
    > >>Thanks
    > >>Tony
    > > not rubber .
    .... or silicone
    what goes on on the upper side makes no difference re leaks. Plastic
    washers just spread the load.
    NT
    NT, Jan 7, 2010
  7. Tonyb
    Guest
    > >news:...
    > > >>waste
    > > >>plastic
    > > >>fits
    > > >>the
    > > >>Thanks
    > > >>Tony
    > > > not rubber .
    > > So the general consensus seems to be to use fernox lsx sealant/plumbersmait
    > ... or silicone
    > NT
    The washer between the sink and the plug stops the water draining when
    the plug is down - leave it out and the sink won't hold water,
    although it won't cause a leak.
    I prefer using these http://www.toolstation.com/shop/Plumbing/Washers Fixings/Basin Mate 1 14/d20/sd2703/p37534
    on the underside rather than using sealant.
    , Jan 7, 2010
  1. Replies:
    15
    563
  2. David McMillan
    Problem shower waste connection
    David McMillan, Sep 3, 2004, in forum: Misc DIY
    730
  3. Vass
    946
    david lang
    Nov 18, 2005
  4. GROVER
    Leaking Sink Waste Disposer
    GROVER, Apr 22, 2011, in forum: Home Repair
    416
  5. Jethro
    14
    883
