leaking oil fired heating boiler warmflow 70/90
Discussion in 'UK DIY' started by curious, Sep 11, 2005.
  1. curious
    curious Guest
    Is it possible to repair a water leak in an oil heating boiler.
    If so is it a long term solution or just a tempory fix?
    How much for a replacement boiler same or different make?
    Thanks.
  2. curious
    John Guest
    "curious" <> wrote in message
    Yes but usually not worth it
    Its usually a temporary fix. The standard for a leak is corrosion showing
    through from the wet side. Repairs usually result in a bigger hole soon
    after!
    Varies - ask at your local heating and plumbing supplier (Plumb Centre?) for
    the same make and model and ask for pricing of similar models by other
    makers such as Firebird, Worcester, Trianco
    John, Sep 11, 2005
  3. curious
    raden Guest
    In message <>,
    curious <> writes
    Where ?
    I'm sure google can help you
    geoff
    raden, Sep 11, 2005
  1. Frances
    Oil-fired central heating control?
    Frances, Oct 2, 2003, in forum: UK DIY
    422
    Frances
    Oct 2, 2003
  2. in2minds
    OT ish... oil fired heating
    in2minds, Nov 1, 2005, in forum: UK DIY
    480
    David
    Nov 9, 2005
  3. Stephen
    boiler: need new oil fired boiler
    Stephen, Aug 5, 2008, in forum: UK DIY
    1,243
    Doctor Drivel
    Aug 23, 2008
  4. Replies:
    14
    600
  5. curious
    518
    curious
    Dec 9, 2010
