leaking lead water mains pipe problem
Discussion in 'Home Repair' started by gamesburn@yahoo.co.uk, Nov 4, 2005.
  1. Guest
    my father's house has a leaking lead inlet water mains pipe. I cant see
    the break as it is covered by the pipe wall bracket, i imagine it is a
    crack. The pipe is dripping a drop once every 10 secs and is in the
    cellar/basement of my father's house.
    How would I do a temporary repair to stop the dripping until the lead
    piping system is replaced?
    Thanks for your help inadvance
    regards
    anthony
    , Nov 4, 2005
  2. sPoNiX Guest
    On 4 Nov 2005 03:08:20 -0800, wrote:
    >Hi,
    You can buy an epoxy based putty especially for this sort of
    situation.
    One such putty is Unibond Express repair, which must be applied to the
    crack when it is dry:
    http://www.unibond.co.uk/loctite/repairxpress.html
    Your loca DIY shed or car spares shop will likely stock it.
    If it's not possible to turn the water off and dry the crack then JB
    Waterweld is worth considering, as it cures under water:
    http://www.jbweld.co.uk/files/prodc.html#WATERWELD
    I'd imagine you can get Waterweld from a local chandlery shop as it's
    used to repair boats.
    sponix
    sPoNiX, Nov 4, 2005
  3. Guest
    Thanks for the info sponix
    , Nov 8, 2005
  4. Guest
    >Hi,
    >regards
    >anthony
    Most hardware stores sell a red rubber in a pack with some cork and
    gasket material. They are about 6 inch squares, under $5.
    Cut a strip of the rubber and put a hose clamp (or two) around it.
    You will have to open and spread the clamp to get it around the pipe.
    Mark
    , Nov 9, 2005
    | >Hi,
    | >regards
    | >anthony
    Not so! Hardware stores are very rare in the UK, they hardly exist in
    towns. In my <mumble> years I have never seen what you describe.
    Dave Fawthrop <dave hyphenologist co uk>
    "Intelligent Design?" my knees say *not*.
    "Intelligent Design?" my back says *not*.
    More like "Incompetent design"
    Dave Fawthrop, Nov 9, 2005
  1. cjiruk
    repair mains lead water pipe
    cjiruk, Oct 2, 2005, in forum: UK DIY
    317
    cjiruk
    Oct 2, 2005
  2. cjiruk
    repair lead mains water pipe
    649
    cjiruk
    Oct 2, 2005
  3. Replies:
    548
    Dave Fawthrop
    Nov 9, 2005
  4. lenny
    1,895
    lenny
    Feb 14, 2007
  5. sm_jamieson
    8
    936
    Roger Mills
    Aug 2, 2007
