lawn mower problem
Discussion in 'Home Repair' started by George Macomber, Jun 10, 2004.
  1. I think are nieghbor put sugar in the gas tank
    of are lawn mower. The plug is now fouled.
    Is the lawnmower ruined or will cleaning
    the tank out and replacing the plug
    fix it.
    thanks
  2. George Macomber
    Halvey Guest
    Do you have a barking dog? =)
    > fix it.
    > thanks
    Halvey, Jun 10, 2004
  3. George Macomber
    jene Guest
    > fix it.
    > thanks
    If it's really sugar in the fuel tank,
    don't waste your time on the plugs.
    jene, Jun 10, 2004
  4. George Macomber
    Randy Guest
    > fix it.
    If it's sugar, it's easy to find out. Shake the mower and then dump the
    gas into a transparent container (perhaps a plastic milk jug) and look
    for white sediment in the bottom. Sugar doesn't dissolve completely in
    gasoline, so most will have precipitated to the bottom.
    If you have been sugared, you should be able to fix the mower, since the
    mower engines are less sophisticated than cars. You may have to
    disassemble the carb to fully clean it, but I'd just remove it and rinse
    it thoroughly several times in clean gasoline.
    You'll want to purge the mower's fuel line and replace the fuel filter
    (if there is one). The plug will have to be cleaned thoroughly and
    probably replaced.
    Be sure to let the engine, carb, and mower dry out a bit before
    restarting it. You don't want to ignite the residual gas that's
    probably still sitting on the mower.
    Randy
    Randy, Jun 10, 2004
  5. George Macomber
    m Ransley Guest
    Sugar shouldnt foul plugs, an old unmaintained rich burning motor will.
    Take apart the carb before you blame anyone and regret it.
    m Ransley, Jun 10, 2004
  6. George Macomber
    Tony Hwang Guest
    > fix it.
    > thanks
    Do you mow at 4 in the morning or 11 in the night?
    Just wondering.
    Tony
    Tony Hwang, Jun 10, 2004
  1. Stuart
    Lawn Mower Problem
    Stuart, May 16, 2004, in forum: UK DIY
    584
  2. Harry Bloomfield
    Lawn mower drive problem?
    Harry Bloomfield, Aug 10, 2005, in forum: UK DIY
    505
    Harry Bloomfield
    Aug 10, 2005
  3. Lawn Mower Problem Solved
    , May 24, 2004, in forum: Home Repair
    260
  4. nsaikia
    15
    430
    Rich256
    Mar 21, 2006
  5. Tankery
    Honda Easty Start Lawn mower problem
    Tankery, Apr 14, 2006, in forum: Home Repair
    313
    Shopdog
    Apr 14, 2006
