Lawn mower Dies after a few minutes?
Discussion in 'Home Repair' started by lbbss, Oct 6, 2008.
  1. lbbss
    lbbss Guest
    My lawn mower (Craftsman 6hp) starts fine and works for a bit but then
    starts dying. After trying this for a few times, then I have a
    harder time to start it. When I prime it and keep trying to start
    it, I check the spark plug and it is not wet from fuel, so maybe there
    is a fuel problem. I left it out side covered, but water might have
    gotten in anyways. So I drain all the fuel and drained the
    carburetor pan from fuel. There was no water in the fuel. I put
    new fuel, check the spark plug too.
    The only other thing that I can think of is that 3 months ago, I
    did hit something hard with the blade. It was making a slightly
    different engine noise for a month or so, but eventually sounded
    normal I think. Any ideas what else I could try?
    lbbss, Oct 6, 2008
  2. lbbss
    zxcvbob Guest
    It could be the flywheel sheer pin. Until you mentioned that ran over a
    shovel thing (or was it a rake this time?) I was gonna say the carb is
    gummed up.
    If it's running too lean, you might try wrapping the air cleaner element
    with a damp paper towel to choke down the air supply.
    But check the flywheel pin; that's cheap and easy.
    Bob
    zxcvbob, Oct 6, 2008
  3. lbbss
    LouB Guest
    You have removed and cleaned the air filter??
    Lou
    LouB, Oct 6, 2008
  4. lbbss
    ransley Guest
    >      The only other thing that I can think of is that 3 months ago,I
    Its fuel or electrical, 2 minutes indicates when the carb is empty it
    dies so a fuel passage or float, does it start whan you force gas in
    by priming, then its fuel related. if more then a few minutes it could
    be the ignition module, see if you get spark after it dies, probably
    need a carb rebuild
    ransley, Oct 6, 2008
  5. lbbss
    lbbss Guest
    yes put a new air filter.
    > Lou
    lbbss, Oct 6, 2008
  6. lbbss
    lbbss Guest
    Gas lawnmower. I tried starting it today again it was difficult.
    When I prime it I can smell the gas, I even see some in the air
    filter. But after pulling the rope many times to try to start it, I
    would expect to see a wet spark plug, but mine is always dry. Last
    time when I unscrewed the bottom of the carb pan, there was gas is the
    small metal pan. Maybe the problem is past that area? Thanks.
    > need a carb rebuild
    lbbss, Oct 6, 2008
  7. lbbss
    TWayne Guest
    Gravity fed fuel or a pulse-pump to feed fuel? Sounds like the carb
    bowl goes empty. I'd remove it and watch the fuel flow for say a cup of
    gas; is it a consistant flow or is it slow, just a drip?
    Dry plug says no fuel; Next is carb in the line. Then the fuel filter;
    those plug easily. Then the fuel tank, usually with a screen over the
    output, inside the tank. Tank could need cleaning, could be a plugged
    fuel filter, fuel not getting to carb, carb plugged or jets plugged.
    Not much more in the ckt.
    This could well be nothing but a plugged fuel filter; changed it too?
    >> could be the ignition module, see if you get spark after it dies,
    >> probably need a carb rebuild
    TWayne, Oct 6, 2008
  8. lbbss
    Rich256 Guest
    On Oct 6, 8:24 am, lbbss <> wrote:
    > Gas  lawnmower.    I tried starting it today again it was difficult..
    > > need a carb rebuild- Hide quoted text -
    > - Show quoted text
    As someone asked earlier, diid you check the flywheel pin? it may be
    sheared just a tiny bit.
    Rich256, Oct 6, 2008
  9. lbbss
    lilo Guest
    Kind of a longshot but check your blade. This same type of problem happened
    with my Craftsman. The blade was out of tightness due to hitting a wooden
    post. It sheared the little knobby things that hold the blade tight and it
    caused a tough time starting..
    "lbbss" <> wrote in message
    >> Lou
    lilo, Oct 6, 2008
  10. lbbss
    lbbss Guest
    would fly wheel pin prevent gas from getting to the spark plug?
    Because that is definitely a problem, I keep priming and pulling and
    then check the spark plug and it is dry as dry can be.
    lbbss, Oct 7, 2008
  11. lbbss
    lbbss Guest
    would that prevent gas from getting to the spark plug? Because that
    is definitely a problem, I keep priming and pulling and then check the
    spark plug and it is dry as dry can be. And would that explain why
    it would dry all of a sudden after it starts?
    lbbss, Oct 7, 2008
    #11
  12. I've seen on Tecumsehs, sometimes gasket between the carb and the engine
    dries out. Might have to remove the carb, put a dab of Permatex #2 non
    hardening gasket crap on the both sides of the gasket, and bolt er back on.
    Christopher A. Young
    Learn more about Jesus
    www.lds.org
    > need a carb rebuild
    Stormin Mormon, Oct 7, 2008
    #12
  1. Replies:
    21
    2,166
    marcusb3495
    Oct 31, 2006
  2. DP
    537
    Stormin Mormon
    Jun 30, 2008
  3. DavidA
    935
    Dave Osborne
    May 7, 2009
  4. David Farber
    407
    David Farber
    Dec 17, 2010
  5. Harold Lathom
    36
    726
    bud--
    Mar 24, 2011
