laminate floor question - wood filler?
Discussion in 'Misc DIY' started by chinlin, Jan 15, 2006.
  1. chinlin
    chinlin Guest
    I recently have laminate floor installed in my apartment, after the
    installation I noticed that some of the boards have gaps ( about the
    size of 1- 1.5mm) between them. I talked to the installer and they
    replied that it was normal and it happens often. However, the gaps
    really bug me. Is there anything I can do to fill the gaps? I purchased
    some wood filler from Home Depot in the same color as the floor. Does
    anybody know if the wood filler will work on the laminate floor?
  2. badgolferman
    badgolferman Guest
    > purchased some wood filler from Home Depot in the same color as the
    > floor. Does anybody know if the wood filler will work on the laminate
    > floor?
    The installer is lazy and is feeding you a line. He did a lousy job.
    If you want to fix it yourself pull up the baseboard at the closest end
    and use a pull bar to slowly tap the board ends closer together.
    "I do not belong to any organised political party: I'm a democrat." ~
    Will Rogers
    badgolferman, Jan 15, 2006
  3. "chinlin" <> wrote in message
    Wood filler will fill the gap(s), but it'll look worse than terrible.
    Kyle Boatright, Jan 15, 2006
  4. Bob
    Bob Guest
    Do you own the apartment? If so, get them back to fix it. If they don't,
    then it depends on how you paid. Can you stop payment on the check. If it
    was a credit card, then you may be able to dispute the charges. Call your
    credit card company. Write them a certified letter, because you'll need that
    if you take them to small claims court. If they were a sub-contractor of a
    store, then write the store a letter also. If you don't own the apartment,
    then it may be best if the owner goes after them.
    Bob, Jan 15, 2006
  1. Mil
    10
    1,520
    Set Square
    Oct 9, 2004
  2. The Medway Handyman
    Laminate Floor Filler
    The Medway Handyman, Aug 18, 2006, in forum: Misc DIY
    25
    1,098
    Andy Hall
    Aug 20, 2006
  3. Robert11
    Wood Filler For Exterior Wood Patching ?
    Robert11, Mar 4, 2007, in forum: Home Repair
    832
    C & E
    Mar 4, 2007
  4. abby
    509
    John Grabowski
    Jul 26, 2008
  5. Jay-T
    Filler for a wood floor?
    Jay-T, Jan 10, 2010, in forum: Home Repair
    557
