Joining new concrete to old
Discussion in 'Misc DIY' started by robgraham, Aug 10, 2006.
  1. robgraham
    robgraham Guest
    I'm adding a shed on the side of my garage.
    It works out that the new concrete floor level will just nicely line up
    with the top of one of the existing concrete steps into the garage -
    makes a nice reference point for the levelling.
    However the existing step has quite a 45 deg. bevel on it's leading
    edge. Do I need to treat this in any way to get the new concrete to
    bond to it ? My concern is that if the bond isn't reasonable, the new
    concrete will break away in time as it is potentially a weak spot.
    Rob
    > Thanks
    > Rob
    Its never a bad idea to chisel some slots and install some sort of metal
    ties in.
    The Natural Philosopher, Aug 10, 2006
  3. robgraham
    Phil L Guest
    > up with the top of one of the existing concrete steps into the garage
    > - makes a nice reference point for the levelling.
    A 45 degree bevel on a step? - are you sure it's not just a kerbstone laid
    flat on it's back?
    Either way, you can't 'chamfer' concrete in this way, you are right to
    assume that it will crack up, the only way to stop this is to give it more
    depth, IE cut out a straight line with a grinder and chisel off an inch or
    two in depth, treat with neat PVA prior to concreting and scrape some slop
    into it.
    Phil L, Aug 10, 2006
  4. robgraham
    robgraham Guest
    > flat on it's back?
    > into it.
    Yes a chamfer would have been a better word; when I cast the steps some
    25 years ago I obviously put a chamfer on the leading edges so that
    they wouldn't chip. OK I'll now have to cut it out !! Thanks for the
    advise.
    Rob
  5. robgraham
    Paul Hodges Guest
    I did something similar 10 years ago.....
    Footings to my garage are a metre wider than the garage (raft foundation).
    My new block built shed was to be roughly 8' wide so needed footings that
    reached beyond the scope of the garage foundations.
    I got two great lengths of angle iron, bent them into large V shaps and
    bolted them to the side of the footings.
    Then I poured the concrete - angle iron was then submerged in concrete.
    OK, no 45 degree thing going on, but that new groundwork has never moved a
    milimeter in 10 years.
    Hope that helps
    Regards
    Paul
    "The Natural Philosopher" <> wrote in message
    >> Thanks
    >> Rob
    > ties in.
    Paul Hodges, Aug 10, 2006
  1. JW
    532
    Guest
    Jun 27, 2004
  2. Replies:
    535
    Cliff Hartle
    Jan 29, 2006
  3. George
    joining new plaster with old
    George, Dec 2, 2006, in forum: Misc DIY
    George
    Dec 4, 2006
  4. Replies:
    875
    Switch
    Feb 11, 2006
  5. Charles C
    Joining new to old plaster
    Charles C, Jul 27, 2010, in forum: UK DIY
    967
    Andrew Gabriel
    Jul 28, 2010
