"J" & "P" Under Sink Drain Traps: Differences Between ?
Discussion in 'Misc DIY' started by Robert11, Jan 19, 2006.
  1. Robert11
    Robert11 Guest
    Hello:
    A bit confused over terminology on this, was wondering if anyone can clarify
    it for me.
    Regarding the typical under sink bathroom drain traps:
    I always thought these U-bend assemblies were called "J" Traps.
    But I see that in some text they term them "P" Traps.
    What are the differences between a J and a P Trap, then ?
    Couldn't find any good pix of these two types; anyone know of any links
    showing differences, etc. ?
    Thanks,
    Bob
  2. Robert11
    RicodJour Guest
    Re: "J" & "P" Under Sink Drain Traps: Differences Between ?
    > it for me.
    http://www.everything2.com/index.pl?node=Elbow trap
    A thousand words is as good as a picture. ;)
    RicodJour, Jan 19, 2006
  3. Robert11
    BobK207 Guest
    Sometime between now & the time I learned my plumbing skills at my
    father's side they came up with all thiese extra BS names
    Rico I found the same webspage but (at least for me) the links to the
    trap types appear broken or do not produce a picture.
    cheers
    Bob
    BobK207, Jan 20, 2006
  4. Robert11
    RicodJour Guest
    That's why I wrote a thousand words are as good as a picture and gave
    it a little smiley. The description should be sufficient for the OP.
    RicodJour, Jan 20, 2006
  5. Robert11
    Guest
    Robert11 wrote:
    > Hello:
    > it for me.
    We call them S & P traps in Australia.
    P traps are shaped like a letter P and S traps are shaped like an S.
    P traps drain sideways & S traps drains down.
    , Jan 20, 2006
  6. Robert11
    buffalobill Guest
    from buffalo ny: don't get "trapped" by the letters, the common P trap
    has both removable nuts. other less common J trap has a captive nut
    [where the short side of the trap has its own nut that screws upward
    onto the threaded wall arm]. there are many varieties of traps in
    plumbing but mostly just replace the kitchen with 1-1/2" and the
    bathroom sink with 1-1/4" often found as a combination sized trap with
    extra insert adapter in the bag for the smaller sink size.
    i agree with the lack of photos.
    buffalobill, Jan 20, 2006
  1. Replies:
    338
  2. miamicuse
    454
  3. Ken Moiarty
    8
    1,126
    Ken Moiarty
    Dec 6, 2005
  4. Robert11
    327
  5. Gary
    89
    2,488
    westom
    Mar 15, 2009
