Is there a freeze-proof copper pipe?
Discussion in 'Misc DIY' started by deanbrown3d@yahoo.com, Jan 26, 2005.
  1. Guest
    Is there such a pipe, copper or otherwise, that doesn't matter if it
    freezes? My pipes up to the upstairs bathroom run within an outside
    wall, and while its inside the insulation it has frozen before, luckily
    never burst, but I don't trust it to do that again!
    , Jan 26, 2005
  2. toller Guest
    "John Hines" <> wrote in message
    > I've not tried it, but since water reaches its maximum volume before it
    > freezes (ice floats), I've had the thought that a water hammer arrestor
    > would do the job, giving the water a place to expand before it freezes
    > solid.
    No such luck. Even with water off and the pipes poorly drained, residual
    water can freeze and break pipes.
    I have never had it happen, but I have had a water filter break because
    there was a little water left in it.
    Supposedly pex will can tolerate freezing. Perhaps someone will elaborate
    on that.
    toller, Jan 26, 2005
  3. "John Hines" <> wrote in message
    > solid.
    It may help in some cases, but often the arrestor is too far away. Water
    expands 17% when it freezes and can easily do lots of damage.
    PEX would be a better product in a potential freeze up though.
    http://www.ppfahome.org/pex/faqpex.html
    Edwin Pawlowski, Jan 26, 2005
  4. Beachcomber Guest
    On Wed, 26 Jan 2005 04:30:48 GMT, "Edwin Pawlowski" <>
    >> solid.
    It's an old story... If you run pipes in an outside wall in a climate
    subject to freezing, you're going to have trouble.
    Best to relocate the pipes in the heated space and cover them with
    insulation if there is any doubt.
    Beachcomber
    Beachcomber, Jan 26, 2005
  5. Guest
    I would put heat tracing on them and insulate.
    , Jan 26, 2005
  1. CathyLee
    Freeze proof barn tap
    CathyLee, Feb 3, 2005, in forum: Misc DIY
    571
  2. Bonnie
    freeze proof faucets
    Bonnie, Apr 22, 2005, in forum: Misc DIY
    541
  3. digitalmaster
    Freeze Proof Outdoor Spigot problem
    digitalmaster, Sep 1, 2006, in forum: Misc DIY
    359
  4. Gio Medici
    Freeze-Proof Faucet Leak
    Gio Medici, Apr 10, 2005, in forum: Building Construction
    325
    Gio Medici
    Apr 10, 2005
  5. Replies:
    12
    330
