Iron on carpet.
Discussion in 'UK DIY' started by jerrybuilt, Oct 29, 2003.
  1. jerrybuilt
    jerrybuilt Guest
    Some person has put down a hot iron on a plastic carpet. This
    has caused a melted patch on the surface. The "crust" is not
    very thick, and the melting not severe, 'though obvious. I guess
    that the fibres have been shortened by 0 to two millimetres.
    Is there a way of camoflaging this iron-shaped mark? I was
    thinking of cutting the "cap" off with a very sharp knife, to
    reveal the un-melted surface underneath, or perhaps trying
    a sanding disk applied gently, perhaps using a frame to
    sand a maximum depth.
    Anyone any ideas?
    be !
    Shop all amazing products and get our special offers!
  2. jerrybuilt
    David Hearn Guest
    "jerrybuilt" <Use-Author-Address-Header@[127.1]> wrote in message
    > Anyone any ideas?
    A sanding disk is likely to heat up/melt the carpet again.
    No chance of moving the furniture?
    David Hearn, Oct 29, 2003
  3. jerrybuilt
    Jon Guest
    > Anyone any ideas?
    > be !
    Cut an irregular shape around the patch and then move a bed / sofa /
    bookcase and cut the same shape out from underneath the object and swap over
    the bits. It does work, but depends on the differential between the wear on
    the two bits of carpet.
    Apart from that, a lawnmower on a very low setting and do the entire
    carpet....
    Jon
    Jon, Oct 29, 2003
  4. jerrybuilt
    Steve Harper Guest
    Claim on the house insurance for a new carpet?
    > Anyone any ideas?
    > be !
    Steve Harper, Oct 29, 2003
  5. jerrybuilt
    Angela Guest
    > Anyone any ideas?
    Why not just claim on your insurance and get a new one?
    Angela
    Angela, Oct 29, 2003
  6. jerrybuilt
    David Hearn Guest
    "Angela" <> wrote in message
    news:bnordm$e58$...
    > news:...
    > > Anyone any ideas?
    Well, firstly requires accidental damage cover.
    Then there's the issue of whether the Contents insurer claims its not
    covered by contents and would be covered by Buildings Insurance, who then
    say that its actually a contents... ;)
    Depending on the excess of the policy, it may not be worthwhile to claim,
    considing the likely increase in premiums, and if he could find an easy way
    of making good without calling in the insurers.
    Ultimately, all claims get covered by other people's premiums, so if
    everyone made unecessary claims we'd all lose out.
    But yes, I think in the end, if the damage is bad, accidental damage cover
    is in place and its worthwhile, then a claim may well be appropriate.
  7. jerrybuilt
    RichardS Guest
    > Anyone any ideas?
    Can you have a go at it with a nice clean wire brush? I've done similar
    things in the past and it certainly helps to recreate the pile somehow and
    separates out any tops of the fibres that may have been fused together.
    Not much you can do about the difference in length of fibres except perhaps
    try and reduce the contrast with the surrounding carpet, perhaps using an
    electric razor or a decent beard trimmer?
    cheers
    Richard
    Richard Sampson
    email me at
    richard at olifant d-ot co do-t uk
    RichardS, Oct 29, 2003
  8. jerrybuilt
    Martin Guest
    > Anyone any ideas?
    > be !
    I did that to a wool carpet 8-10 years back, just left it, after about a
    year of wear you couldn't see it any more.
    Coarse sandpaper or a wire brush in the pile direction may help to separate
    the fibres and hide it, depends on the pile depth.
    Martin, Oct 29, 2003
  9. jerrybuilt
    geoff Guest
    In message <>, jerrybuilt
    <Use-Author-Address-Header@[127.1]> writes
    >Anyone any ideas?
    A rug ?
    >be !
    Hmm, don't seem to be able to read Thai anymore ... oh well
    geoff
    geoff, Oct 29, 2003
  10. jerrybuilt
    John Rumm Guest
    jerrybuilt wrote:
    > Anyone any ideas?
    Iron the rest of the carpet to match ;-)
    Cheers,
    John.
    | Internode Ltd - http://www.internode.co.uk |
    | John Rumm - john(at)internode(dot)co(dot)uk |
    John Rumm, Oct 29, 2003
  11. jerrybuilt
    R W Guest
    When one is reading perfectly legitimate comments and suggestions, then
    one comes across
    > carpet....
    is when one needs a new monitor due to laugh induced beverage damage.
    R W, Oct 30, 2003
    #11
  12. jerrybuilt
    BigWallop Guest
    "R W" <> wrote in message
    news:bnreqi$c7a$...
    > one comes across
    > > carpet....
    ROFLMAO !!!!! Same here. :))
    BigWallop, Oct 30, 2003
    #12
  1. sPoNiX
    Carpet tiles over carpet
    sPoNiX, Apr 19, 2004, in forum: Misc DIY
    650
    sPoNiX
    Apr 20, 2004
  2. John Borman
    1,177
    John Borman
    Jan 9, 2005
  3. Replies:
    17
    953
    Rob Morley
    Jun 10, 2005
  4. JDT2Q
    1,363
    JDT2Q
    May 9, 2009
  5. blueman
    2,166
