intermatic t103 timer motor
Discussion in 'Home Repair' started by Michael.A.Kelley@gmail.com, Nov 11, 2006.
  1. Guest
    I'm having problems with the wiring for the timer motor in my
    intermatic t103 timer (and I'm a novice when it comes to electrical
    wiring).
    Here's some wiring diagrams for the t103:
    http://www.intermatic.com/Default.asp?action=diagram&pid=376&pos=1
    http://www.intermatic.com/images/instruction_sheets/158ts10946-1.pdf
    I currently have a red, white and green (which is ground) coming from a
    fused power box into the timer, and I have a red, white and green
    coming out of my fountain pump. I've connected everything how I think
    it should be - red and white coming from the power box to terminals 1
    and 3, and the red and white coming from the fountain pump are
    connected to 2 and 4. Green is connected to the ground terminal, and
    it's connected to the green wires coming from the power box and the
    fountain pump. The manual lever works just fine, but the clock motor
    doesn't seem to run. I'm little confused about the wiring diagrams -
    should the clock motor go to terminals A and 1, or A and 3? Also, do I
    need to connect anything to terminal A other than the clock motor?
    Also, I'm not entirely clear how the trippers actually trip the switch
    - I've manually moved the dial and it seems like the switch won't move
    at all.
    , Nov 11, 2006
  2. RBM Guest
    Install the green on the ground screw. Install both whites on the screw
    marked "A". The confusing part is where the second leg of the clock motor is
    attached. It appears that it could be "1" or "3". Let's assume it's on "1".
    Put the red from the fuse box on "1" and the red from the fountain on "2".
    That should do it. In the event that the clock doesn't turn, (you will be
    able to tell as it has a visual peep hole to see the gears spinning), change
    your red from fuse box to "3" and red from fountain to "4"
    <> wrote in message
    > wiring).
    > at all.
    RBM, Nov 11, 2006
  3. RBM Guest
    When the trippers are clamped on the dial, they will contact the switch
    mechanism. You can't do it manually because you have to pull the dial before
    it will turn. In pulling the dial the trippers are moved out of reach of the
    switch mechanism
    <> wrote in message
    > wiring).
    > at all.
    RBM, Nov 12, 2006
  4. Guest
    Both white neutrals go to terminal A
    Hot (red from panel) goes to terminal 1, with a jumper to terminal 3 if
    you have a second load to switch.
    Red to fountain goes to terminal 2. A second switched load would go on
    terminal 4 if you installed that juimper to terminal 2.
    > wiring).
    > Here's some wiring diagrams for the t103:http://www.intermatic.com/Default.a...om/images/instruction_sheets/158ts10946-1.pdf
    > at all.
    , Nov 12, 2006
  5. Guest
    Thanks everyone for the help!
    So it turns out that I needed a t104 timer instead of a t103 since the
    t104 supports more voltage. I've gotten the timer moving with the
    t104, but the timer doesn't seem to trip the trippers. I've verified
    I'm getting 240 volts from the wall and out of the timer to the
    fountain pump.
    Now I have only one line and load connected - maybe I only need a SPST
    instead of DPST?
    (I've been buying the DPST because that's what the previous owner had
    installed, though I've never seen the timer work with previous owner's
    setup.)
    > > wiring).
    > > coming out of my fountain pump. ?I've connected everything how I think
    > > connected to 2 and 4. ?Green is connected to the ground terminal, and
    > > fountain pump. ?The manual lever works just fine, but the clock motor
    > > doesn't seem to run. ?I'm little confused about the wiring diagrams -
    > > should the clock motor go to terminals A and 1, or A and 3? ?Also, do I
    > > at all.
    , Nov 26, 2006
  1. Ellie
    Intermatic timer question
    Ellie, Jun 24, 2004, in forum: Home Repair
    377
    Ellie
    Jun 24, 2004
  2. barry martin
    barry martin, Jun 25, 2004, in forum: Home Repair
    371
    barry martin
    Jun 25, 2004
  3. frank1492
    789
    blueman
    May 3, 2005
  4. DiezMon
    More Intermatic wall timer fun
    DiezMon, Dec 8, 2005, in forum: Misc DIY
    8
    385
  5. HamNCheese
    Intermatic T103 vs T104 timer for a pool pump
    HamNCheese, Mar 19, 2007, in forum: Home Repair
    1,012
    HamNCheese
    Mar 21, 2007
