Induction hob cannot be placed over "built under" oven
Discussion in 'Misc DIY' started by Chris, May 25, 2005.
  1. Chris
    Chris Guest
    I am installing a new kitchen and want to place an induction hob over
    an electric built under double oven (i.e. built-in oven under the
    worktop, hob built into the worktop).
    The technical data for the following hob mentions:
    "Not recommended for installation above built under ovens".
    Apparently this is because the electromagnetism / eddy currents
    produced by the hob would interfere with the oven.
    Anyone know if this is the case for all induction hobs or if it is
    restricted to this particular brand (Baumatic) ?
    http://www.tlc-direct.co.uk/Main_In...Baumatic_Appliances_Hobs_Induction/index.html
    Cheers,
    Chris.
    Chris, May 25, 2005
  2. Chris
    Grunff Guest
    Our induction hob (DeDietrich) is installed above our built-under oven.
    The hob instructions said that it was important to ensure adequate
    ventilation to the underside of the hob (there's a cooling fan there),
    but did not state that installing above an oven was a bad idea.
    We've had no problems with the hob or the oven.
    Grunff
    Grunff, May 25, 2005
  3. Chris
    mountfords Guest
    I'll second that. My Siemens hob is situated directly above and has had
    no problems so far.
    mountfords, May 25, 2005
  4. Chris
    OldBill Guest
    > no problems so far.
    Seimens do recommend a higher clearance though if hob is fitted over an
    oven. I think the main consideration is one of ventilation.
    OldBill, May 26, 2005
  5. Chris
    Chris Guest
    Thanks for the replies, maybe it's just particular to the Baumatic
    brand - best avoided I then suppose !
    Chris, May 26, 2005
  6. Chris
    Kevin Guest
    I've just been researching hobs and stuff, and Neff state that a
    worktop depth of 50mm is required when using an induction hob above
    their series 2 and series 4 ovens (out of the ones I checked).
    However, the induction hob itself details that there only needs to be a
    30mm worktop depth above built-under ovens. Also, the series 1 oven
    details don't mention any requirement at all, so this is ambigious to
    say the least. It may be worth contacting the manufacturer to see if
    they can give you more specific reasons for their stated requirements.
    Kevin
    Kevin, Jun 5, 2005
  1. Andy Bernard
    1,340
  2. DIY Novice
    1,047
    tony sayer
    Oct 19, 2004
  3. Sparks
    Induction hob tripping RCD
    Sparks, Apr 21, 2005, in forum: UK DIY
    15
    1,192
    Andrew Gabriel
    Apr 23, 2005
  4. benpost
    built in or built under single oven?
    benpost, Jan 25, 2008, in forum: Misc DIY
    846
    Lobster
    Jan 25, 2008
  5. John Stumbles
    Induction hob - not above oven?
    John Stumbles, Mar 20, 2008, in forum: Misc DIY
    8
    703
    Adrian C
    Mar 22, 2008
