Immersion Stat. Fails to On?
Discussion in 'UK DIY' started by Sam Norris, Dec 10, 2003.
  1. Sam Norris
    Sam Norris Guest
    We use the immersion heater on the hot water cylinder sometimes. The
    other day the 18" thermostat broke and I replaced it this morning. What
    interested me was the old one failed to `on', so the heater heated lots
    until it was making such a noise that we noticed. I'm surprised the
    failure state isn't off. What would happen if I didn't turn it off?
    Also, on removing the old one, the plastic casing around the terminal
    for one of the wires is distorted as if it had melted slightly. Perhaps
    that occurred at the same time as the stat. failed.
    Both new and old are 16A on a 3kW heater.
    Sam.
  2. Ed Sirett
    Ed Sirett Guest
    On Wed, 10 Dec 2003 16:18:01 +0000, Sam Norris wrote:
    > Hi,
    The water would boil, the space where the cold tank would fill with much
    steam/condensation/humidity the cold tank would heat up.
    Eventually if the cold tank was inadequately suppported and/or missing its
    lid it might collapse and drop scalding water below. This is the way
    someone was killed recently.
    However the noise is enough to make any resonable curious person switch
    off the heater.
    Ed Sirett, Dec 10, 2003
  3. Ed Sirett
    Ed Sirett Guest
    >> The other day the 18" thermostat broke and I replaced it this
    >> morning. What interested me was the old one failed to `on',
    > Failure modes of thermostats allow failure to occur to the on or off
    > position.
    > When installing an immersion, it is a good idea to select one with two
    > thermostats. One will be a normal one set to the required temperature. The
    > other should be a manual reset one set 10 degrees higher. This way, the
    > consequences of thermostat failure are reduced. Unvented cylinders are
    > required to have such immersions, but they are a good idea for any cylinder.
    What's more the second thermostat is required to be of the manual reset
    type.
  4. Ed Sirett
    Ed Sirett Guest
    Ed Sirett, Dec 12, 2003
  1. Bob Smith \(UK\)
    Boiler intermittently fails to light
    Bob Smith \(UK\), Oct 26, 2004, in forum: Misc DIY
    12
    1,361
    Bob Smith \(UK\)
    Dec 13, 2004
  2. Replies:
    751
    Ed Sirett
    Jan 23, 2006
  3. jives11
    230
    Calvin Sambrook
    Apr 26, 2009
  4. mapleman
    372
    Oscar_Lives
    Aug 19, 2006
  5. Tim Watts
    8
    589
    harry
    Mar 6, 2011
Share This Page
