How to thaw a frozen septic
Discussion in 'Home Repair' started by kevinmartin33@gmail.com, Apr 3, 2007.
  1. Guest
    Bought a cottage late this past fall. The previous owner had uncovered
    the septic system - I think so prospective purchasers could inspect
    it. We were only at the place once before the snow fell and never
    noticed it was open to the elements. This past weekend we went up and
    quickly found out that the plumbing was blocked. A bit of
    investigation brought me to the tank. Since it was uncovered I was
    able to open it up - it is like an ice cube.
    Any thoughts on thawing it out? Someone has suggested using a steam
    pressure washer. Another idea is a immersion or bucket heater of
    some type.
    , Apr 3, 2007
  2. mm Guest
    >some type.
    Have never done this at all, but... pots of boiling water?
    A garden hose from the kitchen sink with hot water?
    Or just cover it up and wait for it to get back to the temp it would
    have been if had never been uncovered? If it wouldn't have been
    frozen now had it not been uncovered, it will reach that same
    temperature, I would guess, in 3 or 4 days. And then it won't be
    frozen. But again, I'm just guessing. No experience.
    Where are you located?
    mm, Apr 3, 2007
  3. deke Guest
    Either wait or use lots and lots of hot water.
    I'd drain the hot water heater into the commode and also bucket it
    out to the septic tank and every other place that might be iced up.
    Repeat.
    Of course, only do this when the temp remains above freezing.
    On Tue, 03 Apr 2007 04:20:50 -0400, mm <>
    >>some type.
    deke, Apr 3, 2007
  4. avid_hiker Guest
    > some type.
    I would think since you can see into it; then a bag of salt de-icer or
    something similiar put into the septic and then covered.would do the
    trick........but like others......no experience.
    avid_hiker, Apr 3, 2007
  5. Lawrence Guest
    > some type.
    Since spring is here it makes sense to wait since from what I know you
    can't do anything anyway. I live in Northern Minnesota where the
    ground freezes deep and hard. Luckily I haven't had this problem but
    I know that when it happens to someone here they either switch to an
    outhouse or the bucket method. People who don't care for those
    solutions just call in a porta potty.
    Lawrence, Apr 3, 2007
  6. Goedjn Guest
    >some type.
    Elemental sodium. It's the only solution.
    Use small doses.
    Goedjn, Apr 3, 2007
  7. Goedjn Guest
    On Tue, 3 Apr 2007 09:19:48 -0700, "Roger Shoaf"
    <> wrote:
    >"avid_hiker" <> wrote in message
    >news:...
    >> > some type.
    >I would be careful about the salt idea. Septic systems work because the
    >microbes digest the solid matter and if you muck up the chemistry the solids
    >stay solid and your system clogs up.
    >I think the porta potty and waiting for the thaw is your best bet.
    A weed burner would probably work, too.
    Goedjn, Apr 3, 2007
  8. Guest
    >some type.
    Take your wife in there and get naked. Have HOT passionate sex. The
    sexual heat will unthaw it.
    , Apr 4, 2007
  9. Andy Guest
    <> wrote in message
    > some type.
    Amazing what you read here! Why didn't you ask why they uncovered it,
    and why didn't you cover it back up! The mean ground temperature here
    in western pa. is 49 degrees, depending on where you are, it might be about
    the same../. cover it up and it will defrost!>
    Andy, Apr 4, 2007
  10. Jackson Guest
    "Roger Shoaf" <> wrote in message
    > news:...
    >> > some type.
    > solids
    Agreed!
    > Roger Shoaf
    > About the time I had mastered getting the toothpaste back in the tube,
    > then
    > they come up with this striped stuff.
    Jackson, Apr 5, 2007
  11. Jackson Guest
    "Goedjn" <> wrote in message
    >>news:...
    >>> > some type.
    >>solids
    Not if something cracks from the heat change, like the tank!
    #11
  12. KC Guest
    > >some type.
    LOL! The way my certain parts of my anatomy respond to cold, I don't
    think it'd be possible. I wonder how the eskimo's handle that problem?
    -KC
    KC, Apr 5, 2007
    #12
  1. Todd W. Roat
    Chimney Brick freeze / thaw reapir
    Todd W. Roat, Mar 2, 2004, in forum: Misc DIY
    903
    Todd W. Roat
    Mar 3, 2004
  2. Hamilton Audio
    ice on roof - how to thaw?
    Hamilton Audio, Jan 11, 2005, in forum: Misc DIY
    863
  3. James \Cubby\ Culbertson
    Septic Frozen?
    James \Cubby\ Culbertson, Dec 18, 2005, in forum: Home Repair
    27
    502
    – Colonel –
    Dec 23, 2005
  4. Freeze-Thaw requirements
    , Nov 1, 2006, in forum: Building Construction
    339
  5. TheOldFellow
    10
    1,421
    Skipweasel
    Dec 28, 2010
