How to remove the yellowing on my bathtub?
Discussion in 'Home Repair' started by geezer, Dec 31, 2005.
  1. geezer
    geezer Guest
    My bathroom has a skylight, and I think sunlight coming through it is
    the culprit that has caused my bathtub to 'yellow' considerably.
    I have a manufactured home with a plastic tub. I guess it's plastic.
    Certainly not ceramic.
    I can't find any cleaner that will do a thing to remove this ?stain?.
    Anyone know of anything that might help here?
    Geezer
  2. geezer
    crmay Guest
    Have you tried ajax? If that didn't work you could try automotive high
    cutting compound and a drill on a buffer. If that still doesn't work,
    use some wet and dry sandpaper until the stain is gone and then buff to
    a shine with the cutting compound
    crmay, Dec 31, 2005
  3. geezer
    buffalobill Guest
    change the flourescent lights from cool white to warm white and enjoy
    the color.
    possibly rust staining from a hot water tank thinking about failing?
    maybe cigarette smoking accumulation removable with spray nine or dow
    bathroom cleaner with scrubbing bubbles?
    airplane urine leaking thru the skylight? :)
    buffalobill, Dec 31, 2005
  4. geezer
    Chuck B. Guest
    >>Thanks
    >>Geezer
    > I would avoid the suggested aggressive scouring powder suggested. It
    > can damage the tub. However I would consider any of the products
    > recommended for acrylic (plastic) tubs. The original (yellow (not gold)
    > label) BonAmi cleanser can be used as well as an automotive polishing
    > product.
    > In the end there may not be anything that will help. You may want to
    > consider the suggestion to changes lights and enjoy it.
    If the yellowing is caused by iron in your water, try "Iron Out". I use
    it when our dishes get a yellow tinge to them and also the shower stall
    tile gets a treatment occasionally. It's easy to use and won't harm the
    tub surface. Home depot or the grocery store carries the product. Good
    luck. Chuck B.
    Chuck B., Dec 31, 2005
  5. geezer
    Bob Guest
    It's a fiberglass tub, and the lighter colors will yellow over time from UV
    rays. The discoloration is most likely imbedded in the plastic, and there's
    nothing you can clean it with. DO NOT use any abrasive powder. The tub might
    eventually start cracking. Before you decide to replace the whole tub, put
    some type of shade over the skylight, or you'll yellow the new tub also.
    "geezer" <> wrote in message
    > Thanks
    > Geezer
    Bob, Dec 31, 2005
  6. geezer
    Ray Guest
    You may want to consider placing a ultraviolet absorbing clear plastic
    filter under your skylight - it is cheap and available from most window
    glass dealers. This will significantly retard - but not prevent the
    yellowing.
    "Chuck B." <> wrote in message
    news:k4vtf.209477$...
    >>>Thanks
    >>>Geezer
    >> product.
    > If the yellowing is caused by iron in your water, try "Iron Out". I use it
    > when our dishes get a yellow tinge to them and also the shower stall tile
    > gets a treatment occasionally. It's easy to use and won't harm the tub
    > surface. Home depot or the grocery store carries the product. Good luck.
    > Chuck B.
    Ray, Dec 31, 2005
  7. geezer
    geezer Guest
    Re: Re: How to remove the yellowing on my bathtub?
    Indeed! But I wanted to get rid of the yellowing I already have,
    which I guess I may not be able to.
    JW
    >yellowing.
    >>>>Thanks
    >>>>Geezer
    >>> product.
    >> Chuck B.
  8. geezer
    geezer Guest
    Thanks Bobb
    I'll try some of that UV-blocking 'film' I see in hardware stores.
    Geezer
    >news:...
    >> Thanks
    >> Geezer
  9. geezer
    Chuck B. Guest
    Have you considered trying "Iron out"? As I suggested in a previous
    reply? It works in a dishwasher and a cloths washer! It will not harm
    the surface of your tub. See below
    > JW
    >>yellowing.
    >>>>>Thanks
    >>>>>Geezer
    >>>>product.
    >>>Chuck B.
  10. geezer
    mm Guest
    Have you checked with the manufacturers of plastic tubs.
    >Thanks
    >Geezer
    Remove NOPSAM to email me. Please let
    me know if you have posted also.
    mm, Jan 1, 2006
  11. geezer
    mm Guest
    On Sat, 31 Dec 2005 18:01:52 GMT, "Chuck B."
    I tried to Iron it out, but the Iron was flat and the bathtub was
    curvy.
    OK, stupid joke.
    mm, Jan 2, 2006
    #11
  1. Andrew Barnes
    Yellowing eggshell paint
    Andrew Barnes, Apr 17, 2004, in forum: Misc DIY
    1,032
    Stuart
    Apr 17, 2004
  2. Dustin
    Remove bathtub
    Dustin, Nov 6, 2003, in forum: Home Repair
    233
    DOUGLAS SHIPPS
    Nov 8, 2003
  3. jp
    706
  4. jp
    484
  5. Arpil
    remove bathtub drain
    Arpil, Mar 13, 2006, in forum: Home Repair
    326
    Speedy Jim
    Mar 14, 2006
