How to remove "grout" around top of tub
Discussion in 'Home Repair' started by William W. Plummer, Dec 16, 2004.
  1. A friend has a Jacuzzi tub with plastic insert "walls". The was mildew
    on the grout which she attempted to hide with some sort of quick-fix
    grout. The mildew now looks terrible and I want to get rid of it all
    and redo it. What can I use to clean it out but not hurt the tub? A
    sharp chisel might work. Are there solvents or cleaning chemicals?
    Dremel tool? Wire brush???
  2. William W. Plummer
    bill a Guest
    the plastic panel gaps were filled with grout or caulk?
    bill
    "William W. Plummer" <> wrote in
    message news:RImwd.205175$V41.72290@attbi_s52...
    >A friend has a Jacuzzi tub with plastic insert "walls". The was mildew on
    >the grout which she attempted to hide with some sort of quick-fix grout.
    >The mildew now looks terrible and I want to get rid of it all and redo it.
    >What can I use to clean it out but not hurt the tub? A sharp chisel might
    >work. Are there solvents or cleaning chemicals? Dremel tool? Wire
    >brush???
    bill a, Dec 16, 2004
  3. William W. Plummer
    Ron Guest
    There are grout removal tools. Go to the tile section of HD or Lowes. Dremel
    also makes a grout removal attachment.
    Ron, Dec 17, 2004
  1. Grunff
    10
    1,169
    John Stumbles
    Feb 8, 2004
  2. Darrell
    1,087
  3. Martin Hirsch
    Grout or Caulk?? around toilet/sink base
    Martin Hirsch, Jul 18, 2004, in forum: Misc DIY
    751
    jeffc
    Jul 18, 2004
  4. peter
    539
    p-nut
    May 10, 2005
  5. TimR
    653
