How to hang a punchbag
Discussion in 'UK DIY' started by Alec, Oct 13, 2003.
  1. Alec
    Alec Guest
    My son has just bought a punchbag and wants me to hang it from the ceiling.
    It's quite heavy (around 25kg) and a foot in diameter and 4 ft tall. It
    comes with four pieces of 1' webbing attached to the top terminating in a
    metal D ring around 2" diameter. Ceiling of his downstairs room is around 10
    ft high and made of lath-and-plaster, and joists, accessible by listing
    floorboards above. What would be the least complicated way of hanging it
    without bringing the ceiling down or disturbing the plaster?
    TIA
    Alec
    Alec, Oct 13, 2003
  2. Alec
    GB Guest
    "Alec" <> wrote in message
    news:3f8abc64$0$23961$...
    ceiling.
    10
    > TIA
    > Alec
    Find a convenient joist and screw a large hook into it from downstairs room?
    Try to get a hook with a closed eye.
    You'll presumably need a length of rope to hang the metal D ring from if the
    ceiling is ten feet high. Otherwise, you son will only be able to practise
    shots at head height! (You did mean 1' webbing, did you? Not 1'' wide
    perhaps rather longer than a foot long. Now I'm confused.)
    Geoff
    GB, Oct 13, 2003
  3. Alec
    Alec Guest
    "GB" <> wrote in message
    news:bmeju2$rv1$...
    > ceiling.
    a
    around
    > 10
    > > TIA
    > > Alec
    room?
    the
    Thanks. Yes, the webbing is about 1.5 inch wide and about a foot long, and
    will need a rope about 3 ft long to attach to the ceiling hooks.
    Are ceiling and joists (Edwardian construction) meant to take the weight and
    pounding without damage?
    Alec
    Alec, Oct 13, 2003
  4. Alec
    geoff Guest
    In message <3f8abc64$0$23961$>, Alec
    <> writes
    >TIA
    Well apart from other postings about strong joists etc (and there's
    probably quite a bit of sideways force if it's for karate), make sure
    that the height is adjustable
    geoff
    geoff, Oct 13, 2003
  5. Alec
    BigWallop Guest
    news:3f8afaf9$0$23962$...
    > news:bmeju2$rv1$...
    > > ceiling.
    It
    in
    > a
    > around
    > > 10
    listing
    it
    > > > TIA
    > > > Alec
    > room?
    > the
    practise
    and
    > Alec
    Two carbine hooks, a piece of chain and a threaded eye hook will let adjust
    the height to suit your son growing up.
    http://tinyurl.com/qrxt
    http://www.marinestore.co.uk/thestore/carbines.html
    http://www.diytools.com/store/detail.asp?ProductID=34552
    www.basecuritysystems.no-ip.com
    Version: 6.0.525 / Virus Database: 322 - Release Date: 09/10/03
    BigWallop, Oct 13, 2003
  6. Alec
    Dazed Guest
    In article <3f8abc64$0$23961$>, alexis2525
    @SPAMFREEmail.com says...
    Just wondering, have you had a look inside it at all?
    I fancied getting one, but after seeing a thing on Watchdog, where one
    person found theirs was full of nappies, another full of curtains, and
    one found a letter of complaint from another customer about what they
    use to fill the bags - it put me off a little!
    Dazed
    Remove 'NOSPAMX' to reply by E-Mail.
    Dazed, Oct 13, 2003
  7. Alec
    GB Guest
    > news:bmeju2$rv1$...
    > > ceiling.
    It
    in
    > a
    > around
    > > 10
    listing
    it
    > > > TIA
    > > > Alec
    > room?
    > the
    practise
    and
    > Alec
    Alec
    I assume from what you are saying that your son is fairly beefy - not a
    ten-year-old?
    The answer must be that no Edwardian house is built to take Mike Tyson
    beating the shit out of it. The house won't collapse but the plaster may
    well crack, etc.
    In that case it might be sensible to spread the load across several joists.
    I think that is not so much to do with the weight as to do with the twisting
    force on the joist, especially as you don't want to loosen the plaster. I
    have seen these things fixed to the ceiling with a large piece of thick
    plywood say 6 feet square (depends on your joist spacing) screwed into each
    of the joists it spans.
    I have no idea if that is strictly necessary. If you have nice mouldings on
    the ceiling, I would strongly suggest some reinforcement as a preventitive
    measure.
    Geoff
    GB, Oct 14, 2003
  8. Alec
    Dee Guest
    You can hang from the wall. Look up "folding bracket" on google and you'll
    find a number of fitness and boxing suppliers shops selling them
    AndyP
    ceiling.
    10
    > TIA
    > Alec
    Dee, Oct 15, 2003
  9. Alec
    DKSanders Guest
    I used a large 'Eye' bolt with a screw threaded stem and simply screwed this
    into a joist at the desired position (or at least as near to it as I could
    find a joist). Used a piece of chain from the local hardware store to get
    the height right.
    "Dee" <> wrote in message news:bmj8bm$1dra$...
    > AndyP
    > ceiling.
    a
    around
    > 10
    > > TIA
    > > Alec
    DKSanders, Oct 24, 2003
  10. Alec
    Marcus Fox Guest
    "DKSanders" <> wrote in message
    news:bnc8on$dof$...
    this
    > the height right.
    you'll
    > > AndyP
    > > ceiling.
    It
    in
    > a
    > around
    > > 10
    listing
    it
    My brother drilled through the ceiling joist from the loft into his room.
    His punchbag is 6ft by 1ft diameter. He bought bolts long enough from the
    local hardware store, with washers and nuts to fit. However, when he punches
    it, it shakes the ceiling and upstairs lath/plaster walls a bit, but my fish
    don't seem to be bothered by it.
    Marcus
    Marcus Fox, Oct 25, 2003
  1. TheScullster
    1,545
    TheScullster
    Mar 10, 2005
  2. Seri
    491
  3. Barnsey
    BEST METHODS TO HANG GATES
    Barnsey, Jul 19, 2005, in forum: UK DIY
    421
    Steve Firth
    Jul 19, 2005
  4. Peter
    488
  5. Replies:
    552
    Weatherlawyer
    Sep 28, 2006
