How to deal with a furnace with a need to bleed
Discussion in 'Home Repair' started by Aaron, Jan 26, 2004.
  1. Aaron
    Aaron Guest
    This is the second winter in my "new" house -- furnace is approx 15
    years old. Runs on oil -- tank is outside in very cold climate, so oil
    is mixed with kerosene by fuel company. The furnace has an issue in
    that, as the oil volume in the tank decreases, air seems to sneak into
    the line. Last year this occurred reliably at 1/4 tank (according to
    the plastic gauge); this year it has begun to happen with as much as
    1/3 tank remaining.
    Generally, when I discover that the furnace has stopped running, I can
    bleed the line for approx. 10 seconds, see the pink oil sputter out
    air, turn to a richer black color, and close the line. The furnace
    kicks in and will often run for awhile again (possibly days, if
    necessary) until at some point air gets into the line again. I sense
    that as oil volume continues to decrease, the need to bleed becomes
    more frequent. The problem disappears when the next oil delivery fills
    up the tank.
    This is a one line system. My furnace 'guy' says that a two line
    system will fix the problem, but he (working alone, and somewhat
    older) is uncomfortable doing the work in the extreme cold of winter
    (line runs through a low crawlspace; oil tank and furnace on opposite
    sides of house).
    My questions are (a) is he right? (his price for installing a second
    line was quite reasonable) and (b) is there *anything* I can do this
    season to help? Waiting until the furnace stops (often in the middle
    of the night) to wake up to a cold house is inconvenient to say the
    least.
    thanks!
    Aaron
    Aaron, Jan 26, 2004
  2. Aaron
    Speedy Jim Guest
    Aaron wrote:
    > Hi,
    > 1/3 tank remaining.
    > up the tank.
    > sides of house).
    > least.
    > thanks!
    > Aaron
    I wonder if the kero mix is part of the problem?
    A 2-pipe system will likely solve it.
    What if you pulled the new copper line (even a temp route)
    and left the final hookup to him?
    Jim
    Speedy Jim, Jan 26, 2004
  1. Moonshine
    445
    Moonshine
    Jul 21, 2004
  2. Paul J S Green
    CH Pressure Vessel - do i need bleed valve
    Paul J S Green, Jun 23, 2006, in forum: UK DIY
    402
    Paul J S Green
    Jun 23, 2006
  3. Auto Lover
    Need advice on how to deal with a neighbor
    Auto Lover, Jul 13, 2003, in forum: Home Repair
    14
    355
    meirman
    Jul 17, 2003
  4. jay
    10
    502
    Tekkie
    Mar 3, 2005
  5. Aaron
    354
    daytona
    Jan 26, 2004
