How many bags of Portland Cement for a CU Yard?
Discussion in 'Home Repair' started by alvinamorey@notmail.com, Nov 6, 2007.
  1. Guest
    They are 90lb bags. From what I recall, it was 3 bags per cu yard.
    Yet I got this guy at the local lumberyard who insists I need 5 bags
    per... Sounds to me he is trying to make more money...
    I am referring to a standard mix of 1 part portland, 2 parts sand and
    3 parts stone.
    It's been awhile since I made cement so I am asking to be sure. I'm
    checking into the cost to make my own from scratch rather than truck
    in some ready mixed stuff in a tub.
    , Nov 6, 2007
  2. Grandpa Guest
    In article <>,
    "Bob F" <> wrote:
    > I don't think so.
    > "The Freon Cowboy" <> wrote in message
    > news:...
    > > 3
    I don't think so either.
    It will depend on the size of the aggregate; see:
    http://www.cement.org/tech/faq_cement.asp
    Grandpa
    Killing all posts from Google Groups
    The Usenet Improvement Project:
    http://improve-usenet.org/
    Grandpa, Nov 6, 2007
  3. zxcvbob Guest
    > 3 parts stone.
    4 1/2. Five if you mix it a little stronger. Don't add too much water.
    Best regards,
    Bob
    zxcvbob, Nov 6, 2007
  4. Doug Miller Guest
    >3 parts stone.
    Premix aggregate yields 2/3 cubic FOOT of concrete per 90# bag.
    That's 27 / (2/3) = 40.5 bags of aggregate per cubic yard.
    So if you're making your own mix, with the cement being 1 part in 6, you'd
    need 40.5 / 6 = just under 7 bags.
    Regards,
    Doug Miller (alphageek at milmac dot com)
    It's time to throw all their damned tea in the harbor again.
    Doug Miller, Nov 6, 2007
  5. Oren Guest
    Buy five and take two back; or one.
    Oren
    I have not failed. I've just found 10,000 ways that won't work. Thomas A. Edison
    Oren, Nov 6, 2007
  6. dpb Guest
    Joseph Meehan wrote:
    > Note: cement and concrete are not the same thing at all.
    > Concrete comes in different size bags. Concrete is formulated to
    > different specifications and strengths.
    It would be the cement that comes in the bags...
    dpb, Nov 7, 2007
  7. Harry K Guest
    Errm..you can also buy premix (dry) concrete in the bag.
    Harry K
    Harry K, Nov 7, 2007
  8. DanG Guest
    Gfretwell gave you the correct answer.
    When ordering or specifying concrete today, it is done by
    requesting a PSI strength depending on how the concrete is to be
    used. 2500# for residential footings, minimum; most commercial
    work is speced at 3500#; tilt up and prestress run 4500-6000#.
    Each excess gallon on water per yard above the design water/cement
    ratio reduces the strength by 500#, so you will often see
    references to not using too much water.
    The very old method of ordering, mixing, or thinking about
    concrete as xxx number of sacks per yard is not used anymore, but
    most concrete people (at least we old ones) do understand the
    terminology.
    It kinda ends up knowing what you are doing with the concrete, the
    stresses to which it will be exposed, your expectations for the
    finish product, etc. 3 sack will set up, get hard, and will
    crack. 6 sack will set up, get hard, and will crack. The six
    sack can take a great deal more load before crushing.
    Your call. There is an excellent explanation with facts and
    figures here: http://www.wikihow.com/Make-Concrete
    ______________________________
    Keep the whole world singing . . . .
    DanG (remove the sevens)
    <> wrote in message
    > yard.
    > bags
    > sand and
    > 3 parts stone.
    > I'm
    > truck
    DanG, Nov 8, 2007
  9. Guest
    >terminology.
    For a simple feedshed floor, I only need the minimum. It's only for
    me to walk on. On the other hand, I always make my concrete more
    durable than that sack-crete. That stuff always seems weak and
    inferior. (not enough portland in it).
    , Nov 8, 2007
  10. Harry K Guest
    > >terminology.
    > >figures here:http://www.wikihow.com/Make-Concrete
    > inferior. (not enough portland in it).- Hide quoted text -
    > - Show quoted text -
    Yep, I buy the sack-crete and add 1 bag of portland. Add about a
    coffee can of portland per bag when mixing. Excess is kept in one of
    the ubiquitous white buckets with the sealing top. Seems to keep for
    years that way.
    Harry K
    Harry K, Nov 8, 2007
  1. Al
    1,138
    Rick Hughes
    Aug 15, 2003
  2. George
    Portland cement
    George, Dec 17, 2007, in forum: UK DIY
    374
    newshound
    Dec 17, 2007
  3. Hiring
    327
    dadiOH
    Aug 30, 2004
  4. Replies:
    388
    Doug Miller
    Apr 1, 2006
  5. Tim
    334
    Robert Allison
    Mar 20, 2008
