How long does a bag of wood stove pellet last?
Discussion in 'Home Repair' started by needin4mation@gmail.com, Nov 20, 2005.
  1. Guest
    Tthe 40 lb bag. How long does it last, if say I burned a fire 8 hours
    a day or longer? Thanks.
    , Nov 20, 2005
  2. Dan C Guest
    The question can't be answered. Depends on how hot/fast you are running
    the stove. Why don't you just try it, and find out?
    If you're not on the edge, you're taking up too much space.
    Linux Registered User #327951
    Dan C, Nov 20, 2005
  3. Guest
    In a 24 hour day I burn approx. 40-60 pounds.
    , Nov 20, 2005
  4. Tim Killian Guest
    Greg O wrote:
    > -- <> wrote in message
    > news:...
    > A better question would be how many BTU's per bag.
    > Greg
    Wood pellets average 8200 BTU/pound, so a 40 pound bag has about 330K
    BTUs. The newer stoves are probably 85%+ efficient, so that yields about
    279K BTUs of delivered heat per 40# bag.
    Tim Killian, Nov 20, 2005
  5. Guest
    Because I don't want to spend $2000 on a stove for an experiment.
    , Nov 20, 2005
  6. Guest
    That's sounds like it could be VERY expensive.
    , Nov 20, 2005
  7. Tim Killian Guest
    At the current price of about $200/ton, wood pellets are about half the
    cost per BTU compared to propane or fuel oil. Natural gas is still
    cheaper, but that could change if the price surges this Winter.
    Tim Killian, Nov 21, 2005
  8. BobK207 Guest
    take a look at
    http://www.fpl.fs.fed.us/documnts/techline/fuel_value_calculator.pdf
    how much pellet wood you consume is a function of how big a fire you're
    burning
    which is driven by:
    size of heated space
    indoor temp
    building insulation
    outdoor conditions
    asking "How long does a bag of wood stove pellet last?"
    is like asking "How long will a 40 lb bag of dog food last?"
    forever if you don't have a dog, not very long if you're running a dog
    team everyday
    cheers
    Bob
    BobK207, Nov 21, 2005
  9. Goedjn Guest
    Hmmm.... I wonder if dogfood will burn in a pellet
    stove. No reason why it shouldn't.
    Goedjn, Nov 21, 2005
  10. >> At the current price of about $200/ton, wood pellets are about half the
    >> cheaper, but that could change if the price surges this Winter.<<
    All wood gives off about the same amount of heat PER POUND.
    Last year a face chord of firewood was about $50.00 to $60.00.
    A ton of pellets was $180.00.
    A face chord of wood weighs about 1000 pounds so 2 face chord weigh about
    the same as a ton of pellets.
    So wood is 2/3 the cost of pellets for the same amount of heat.
    In the advertisements they show a smiling guy emptying a bag of pellets into
    the stove like the last time he did it was a week ago.
    I can burn 150 pounds of wood per day when it is cold out.
    That's almost four 40 pound bags PER DAY.
    Either way, it's a lot of work.
    I think getting one of those ventless heaters is the way to go.
    We use one when it is 35ยบ or more outside because the wood stove would make
    it too hot in the house.
    They are not recommended for heating your house, just supplemental heat.
    We have no problem with moisture, running it.
    JerryD(upstateNY)
    JerryD\(upstateNY\), Nov 24, 2005
  1. hotORcold
    How Long Does Vinyl Siding Last?
    hotORcold, Aug 26, 2003, in forum: Home Repair
    378
    hotORcold
    Aug 26, 2003
  2. orangetrader
    How long does paint last?
    orangetrader, Sep 30, 2004, in forum: Misc DIY
    16
    604
  3. northcountry
    1,067
    northcountry
    May 16, 2005
  4. Replies:
    619
  5. Steve B
    Wood Pellet Stove Firebox Heat Treating
    Steve B, Dec 30, 2012, in forum: Home Repair
    361
    hr(bob)
    Dec 31, 2012
