How level does the floor has to be for laminate flooring
Discussion in 'Misc DIY' started by rkhazin, Nov 8, 2005.
  1. rkhazin
    rkhazin Guest
    I am planning to lay laminate flooring over the entire basement floor
    but 60% of it is covered by 1/8" vinyl tiles and the rest bare
    concrete. Can I lay over it as is or do I need to level the floor first
    by stripping all the tiles or perhaps cover the bare concrete with 1/8"
    linoleum.
    Suggestions?
    Ray
  2. Guest
    rkhazin wrote:
    > Hi,
    > linoleum.
    > Suggestions?
    > Ray
    Greetings,
    1/8" is too much. Harbor Freight tools had a cheap pneumatic floor
    scraper on special not too long ago. That might make your job a lot
    easier. If a) it is still on special and b) you buy it for this one
    job let me know and I might buy it from you for a reduced price used.
    Otherwise I will just wait until it goes on special again.
    Hope this helps,
    William
    , Nov 8, 2005
  3. Bert
    Bert Guest
    rkhazin wrote:
    > Hi,
    > linoleum.
    > Suggestions?
    > Ray
    Couldn't you just use floor leveling compound to feather out the
    difference?
    MikeB
    Bert, Nov 9, 2005
  4. Colbyt
    Colbyt Guest
    "rkhazin" <> wrote in message
    > Hi,
    > linoleum.
    > Suggestions?
    > Ray
    At the risk of sounding unhelpful, may I suggest you read and follow the
    directions included with the product.
    I seem to recall 1/8" deviation in X feet. Yes you are going to need to
    remove the tiles. After you do that you may still need to skim coat and
    level the floor. Most basement floors do not meet the minimum standards set
    for a proper laminate installation. Concrete floors may look level but they
    aren't.
    Colbyt
    Colbyt, Nov 9, 2005
  5. Guest
    Have you given thought to any moisture problem perhaps affecting that
    laminated flooring? I think I would want to be sure there was no
    moisture coming up through the concrete..
    Jack
    , Nov 9, 2005
  6. "rkhazin" <> wrote in message
    > Hi,
    > linoleum.
    > Suggestions?
    > Ray
    Are you talking a Floating or Glue down Floor.
    Sacramento Dave, Nov 9, 2005
  7. "" <> wrote in message
    > Hope this helps,
    > William
    If it's this one,
    http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=37073
    it's on sale now. Not sure if you saw it lower. I'm picking one up this
    week to work on my floor.....long story made short,
    I'm having to remove self leveling concrete from the floor I was trying to
    flatten. I hope it works!
    Cheers,
    cc
    James \Cubby\ Culbertson, Nov 9, 2005
  1. AMO
    595
  2. The Medway Handyman
    Level or looking level?
    The Medway Handyman, Jun 27, 2006, in forum: UK DIY
    27
    758
    raden
    Jun 29, 2006
  3. Jeff
    14
    692
    The Natural Philosopher
    Mar 25, 2008
  4. a1esta
    555
    Johnny V. Mullins
    Feb 24, 2007
  5. Replies:
    359
