How do you tell if a toilet is properly seated
Discussion in 'Misc DIY' started by Ultraglide, Jun 19, 2004.
  1. Ultraglide
    Ultraglide Guest
    I had to take out the toilet in one of my bathroomw so that we could
    wallpaper the wall behind it. When I replaced it, I put a new seal.
    Lately, I have noticed that the grout in the ceramic floor is getting
    damp and spreading away from the toilet. There is also what appears to
    be a stain on the floor at the back. I am assuming that the toilet is
    not properly sealed to the drain. I don't recall if I just used one of
    the rings made just of beeswax or one with a plactic ring and beeswax.
    How do I know when it is correctly sealed? There are no apparent cracks
    in the toilet itself.
    Any suggestions?
    Take out the trash to reply
  2. Ultraglide
    DanG Guest
    If it is showing water anywhere at the base, it is not properly
    sealed. It is not rare to need 2 wax rings. I usually buy the
    one with the plastic sleeve and one plain one. If the floor
    flange is at or below the floor level, I start right out with 2.
    If it is slightly above the floor level, I try it with 1.
    Keep the whole world singing. . . .
    DanG
    "Ultraglide" <> wrote in message
    could
    seal.
    getting
    appears to
    toilet is
    one of
    beeswax.
    apparent cracks
    > Any suggestions?
    DanG, Jun 19, 2004
  3. Ultraglide
    Ultraglide Guest
    Thanks, that's what I wanted to know, whether to use more than one wax
    seal. I realized after the original post, that they don't use beeswax
    anymore.
    > DanG
    > news:...
    > could
    > seal.
    > getting
    > appears to
    > toilet is
    > one of
    > beeswax.
    > apparent cracks
    > > Any suggestions?
    Ultraglide, Jun 20, 2004
  4. Ultraglide
    RB Guest
    Ah, beeswax. Those were the good old days. Now it comes from an oil
    well unless you have a hive in your pasture.
    I'm looking at Fernco's toilet seal for a new bath I'm putting in. It
    looks like the best solution and HD carries Fernco.
    http://www.fernco.com/FTS.html
    RB
    > Any suggestions?
    RB, Jun 20, 2004
  5. Ultraglide
    Adiabatic Guest
    The top of the flange should be level (or near to) with the finished
    floor. If it is lower then get a spacer ring that goes between the
    flange and the sealant ring.
    On Sat, 19 Jun 2004 17:27:42 -0400, Ultraglide
    >Any suggestions?
    Adiabatic, Jun 22, 2004
  1. John
    410
    Murray Peterson
    Apr 22, 2004
  2. removing seated tailpiece
    , Jul 3, 2006, in forum: Home Repair
    234
    Speedy Jim
    Jul 3, 2006
  3. BobH
    14
    477
    Bud--
    Dec 4, 2006
  4. Jonathan Grobe
    13
    1,104
    bud--
    May 30, 2008
  5. AC/DCdude17
    16
    343
