hot water flow restrictor a good idea?
Discussion in 'UK DIY' started by Mike, Dec 13, 2008.
  1. Mike
    Mike Guest
    Hi all
    Just had old heating system (indirect tank for hot water) replaced
    with closed combi.
    I general i'm pretty happy with the results but was surprised to
    discover that the flow of hot water is not restricted. As a result if
    hot taps are turned on too far the water is cooler than required. On
    reading the boiler manual (Biasi Garda he 28kw) it seems restrictors
    are only fitted to the less powerful boilers in the range. it seems
    that for our boiler a restrictor is not included as standard but can
    be added if required.
    Now i'm wondering about getting the plumber back to do this (assuming
    it's not a diy job?) but not sure if it's worth bothering because:
    a) maybe there are some cons against getting the flow restricted ?
    presumably if flow is restricted to produce hot enough water in winter
    then, in summer, when mains water is warmer the boiler could
    potentially achieve a greater flow at the required temp (but we will
    not be able to use this potential if restrictor fitted - if i've
    understood how they work correctly?)
    b) we intend to change all our taps within the next year, so maybe it
    would be possible / easier to limit the flow at the tap some how?
    As always any advice will be much appreciated
    Mike, Dec 13, 2008
  2. Mike
    Ed Sirett Guest
    On Sat, 13 Dec 2008 06:51:05 -0800, Mike wrote:
    > Hi all
    > Just had old heating system (indirect tank for hot water) replaced with
    > closed combi.
    > reading the boiler manual (Biasi Garda he 28kw) it seems restrictors are
    > only fitted to the less powerful boilers in the range. it seems that for
    > our boiler a restrictor is not included as standard but can be added if
    > required.
    > it's not a diy job?) but not sure if it's worth bothering because: a)
    > then, in summer, when mains water is warmer the boiler could potentially
    > achieve a greater flow at the required temp (but we will not be able to
    > use this potential if restrictor fitted - if i've understood how they
    > work correctly?)
    It is almost always better to restrict the flow near the tap. If every tap
    suffers from the same problem then restricting the inlet to the boiler
    might work OK. Many boilers have valve to do just this.
    The FAQ for uk.diy is at http://www.diyfaq.org.uk
    Choosing a Boiler FAQ http://www.makewrite.demon.co.uk/BoilerChoice.html
    Ed Sirett, Dec 13, 2008
  3. Mike
    Mike Guest
    Ed, Problem is with all taps and i've found the valve you mentioned so
    i'll try adjusting it. Thanks for your help
    Mike, Dec 13, 2008
  4. Mike
    newshound Guest
    I had the same problem; originally I restricted the flow after the boiler
    with a gate valve (crude but convenient), but it was very noisy. I fitted a
    proper pressure regulating valve on the cold water inlet to the boiler,
    which is quiet and gives very fine control.
    This one is from BES (there are others from BES and Screwfix)
    18862
    DO4 pressure reducing valve
    £19.14
    If your mains pressure is high you might see if such a valve can be fitted
    before the cold taps as well, although that wasn't practicable in my house
    because I wanted full mains pressure going to the loos and the shower header
    tank for speed of filling.
    newshound, Dec 13, 2008
  5. "newshound" <> wrote in message
    > 18862
    > £19.14
    > header tank for speed of filling.
    You fitted the wrong valve. That is a pressure reducing valve not a FLOW
    REGULATOR.
    The proper valve is:
    BES Part number: 17527 flow cartridges less than £1.
    http://www.bes.co.uk
    This "regulates" flow, not pressure. It will lower flow and maintain the
    pressure.
    If a combis is rated say 12 litres/min a 12 litre cartridge can be fitted in
    the cold inlet to the combi, so you always get 12 litres/min. Or, fit one
    at the hot bath tap. The rest of the outlets will not exceed the 12
    litres/min.
    You could have a 12 litre regulator on the cold inlet and by-pass around it
    with a 1/4 turn valve. Have it turned off in winter so all flow goes
    through the regulator, and on in summer, by-passing the regulator. In
    summer cold water mains temperature is higher and higher flowrates are
    achievable.
    Doctor Drivel, Dec 14, 2008
  1. Replies:
    905
    Rob Morley
    Jun 21, 2005
  2. petek
    shower flow restrictor
    petek, Jan 15, 2008, in forum: Misc DIY
    9
    2,377
    George Duff
    Jan 17, 2008
  3. Thomas G. Marshall
    Hansgrohe Shower Head: Removing flow restrictor
    Thomas G. Marshall, May 31, 2006, in forum: Misc DIY
    1,531
  4. VQ
    548
  5. Richard Tobin
    Flow restrictor?
    Richard Tobin, Sep 19, 2013, in forum: UK DIY
    25
    746
    Onetap
    Sep 23, 2013
