Hooking up gas dryer...
Discussion in 'Home Repair' started by blueman, Dec 14, 2004.
  1. blueman
    blueman Guest
    We just built a new laundry room and had a licensed plumber run the
    gas line and shutoff up to the dryer area.
    When the dryer arrives, do I need to call in the plumber to hook it up
    or is it a straightforward DIY project?
    (I have no problem doing minor (water) plumbing and electrical, but am
    more wary about gas, so I wanted to get advice here first...)
    up
    am
    This might help to see if you want to try this or not....
    http://www.applianceaid.com/gasconnector.html
    jeff.
    Appliance Repair Aid
    Appliance Repair Aid, Dec 14, 2004
  3. blueman
    Phisherman Guest
    Hooking up a gas appliance is easy, but if not done correctly could be
    a hazard. Sometimes the gas company will hook the appliance up for
    free or a small charge. I used a gas flex hose and Teflon tape to
    hook up the dryer to the shut off valve. Then I tested the
    connections with soapy water, then tested again after using the
    appliance. You may smell gas (the nasty additive that is) the first
    time it is hooked up, but not after that.
    Phisherman, Dec 14, 2004
  4. "William Deans" <> wrote in message
    > c) attach a piece of flexable gas hose from the dryer to the gas line
    Better check on that. It has been a while since I did any gas hookups, but
    flex line was NOT permitted on any appliance except a stove.
    Edwin Pawlowski, Dec 14, 2004
  5. blueman
    John Guest
    What does code call for in earthquake prone areas, such as San Francisoc? I
    can't see black iron pipe being a good idea to be run to every appliance,
    furnace, etc. just to permit things to give a little without breaking.
    John, Dec 14, 2004
  6. blueman
    willshak Guest
    On 12/13/2004 9:55 PM US(ET), Edwin Pawlowski took fingers to keys, and
    typed the following:
    Everything in my house that uses gas has a flex line between the gas
    line and the appliance, and that includes a dryer, range, water heater,
    and fireplace. All inspected and approved. The house was built in 1984,
    and the fireplace was installed just last year.
    willshak, Dec 14, 2004
  7. blueman
    mikey Guest
    I'd have the licensed plumber hook it up for you.
    (Surprised he didn't offer to include it in your job)
    Seems like the incremental cost to have him complete
    the job wouldn't be a big deal. Plus, if he does the
    whole job and there is any issue what-so-ever, he
    would likely come look at it (no room for finger
    pointing).
    mikey.
    mikey, Dec 14, 2004
  8. OK, so tell him how soapy water checks for leaks. And then tell him what to
    do if the soapy water changes color.
    Christopher A. Young
    Learn more about Jesus
    www.lds.org
    www.mormons.com
    news:1102989864.9a29485adc7a919fa94877c26d2900d4@teranews...
    Greetings,
    You can do it yourself.
    a) turn off the gas valve
    b) unscew the gas line cap
    d) turn the gas back on
    e) check for leaks with soapy water
    Hope this helps,
    William
    Stormin Mormon, Dec 14, 2004
  9. On 2004-12-14, Phisherman <> wrote:
    > I used a gas flex hose and Teflon tape to hook up the dryer to the
    > shut off valve.
    I have wondered about using Teflon tape with this sort of flexible gas
    line. I believe it is a flare fitting between the adapter and the
    flexible line itself. Wouldn't that mean that Teflon tape on the
    threads is superfluous, since the connection is made as the two flared
    surfaces mate? All you need to do, I would think, is tighten the nut
    full so the two surfaces mate. Is this correct?
    Thanks, Wayne
    Wayne Whitney, Dec 14, 2004
  10. blueman
    HeatMan Guest
    "Wayne Whitney" <> wrote in message
    > > shut off valve.
    First off, if there is a warranty claim on the gas valve and the
    manufacturer sees teflon tape in the works of the gas valve, the claim will
    be denied. The tape will come off and possibly keep the valve from fully
    closing.
    You use thread compound on the pipe threads, not on the flare threads. If
    you have to ask questions like this, ask yourself "is it worth the safety of
    my family to possibly endanger them if I mess up?" Electricity has more of
    a chance to kill you, but a gas leak can kill everyone in your house.
    > Thanks, Wayne
    HeatMan, Dec 14, 2004
  11. blueman
    Pop Guest
    Good reference page, IMO. I got a chuckle out of the following
    excerpt, too:
    "or extreme vibration will cause mental fatigue "
    MeNtal fatigue? Well, probably, when I think it through. <g>
    Pop
    "Appliance Repair Aid" <> wrote in message
    run the
    hook it
    | up
    electrical, but
    | am
    | Hi,
    | jeff.
    Pop, Dec 14, 2004
    #11
  12. blueman
    Phisherman Guest
    On Tue, 14 Dec 2004 05:38:38 GMT, Wayne Whitney
    >> shut off valve.
    >Thanks, Wayne
    If there is a flared end no Teflon nor sealer should be used. But
    still, check for leaks.
    #12
    > excerpt, too:
    > Pop
    Ooops....typo ;)
    jeff.
    Appliance Repair Aid, Dec 15, 2004
    #13
  14. Appliance Repair Aid, Dec 15, 2004
    #14
  1. Rick Hughes
    Hooking up phone line to patch panels
    Rick Hughes, Dec 16, 2006, in forum: UK DIY
    13
    2,088
    Andrew Gabriel
    Jan 2, 2007
  2. Jason
    Hooking BBQ to Gas Stub
    Jason, Jun 23, 2003, in forum: Home Repair
    1,639
    CBHvac
    Jun 24, 2003
  3. Replies:
    1,118
    Beachcomber
    Apr 18, 2006
  4. Replies:
    613
    Edwin Pawlowski
    Apr 30, 2006
  5. alaric
    Hooking up a dryer
    alaric, Mar 18, 2007, in forum: Home Repair
    321
    Charlie Bress
    Mar 18, 2007
