Honeywell Thermostat: "Change Filter" Msg. Question
Discussion in 'Home Repair' started by Robert11, Feb 9, 2007.
  1. Robert11
    Robert11 Guest
    Hello,
    Have a gas fired, hot air furnace.
    Last year they put in on of these really fancy, 7 day programmable Honeywell
    thermostats for it.
    Works fine.
    Every month or so, I replace the filter.
    The thermostat has just come up with a message to change the filter.
    Am I correcdt that this message is based purely on time elapsed, and that I
    never "reset" it at the
    time I changed the filter (don't know how to) ?
    In other words, it really does Not monitor the filter's condition at all,
    just elapsed time ?
    Right ?
    Thanks,
    B.
  2. Robert11
    lp13-30 Guest
    You are correct-- the thermostat measures run time. It has no way to
    actually monitor the filter itself. Larry
    lp13-30, Feb 9, 2007
  3. Re: Honeywell Thermostat: "Change Filter" Msg. Question
    On Feb 9, 8:37 am, "Robert11" <> wrote:
    > Hello,
    > thermostats for it.
    > Works fine.
    > just elapsed time ?
    > Right ?
    > Thanks,
    > B.
    Eric in North TX, Feb 9, 2007
  4. Re: Honeywell Thermostat: "Change Filter" Msg. Question
    You are correct sir. There is a sub menu to turn off that message, I'd
    have to get the book out to tell you how, but my Honeywell did that
    too. I think it is aimed at the big once a year filters.
  5. Robert11
    George Guest
    On Feb 9, 9:37 am, "Robert11" <> wrote:
    > Hello,
    > thermostats for it.
    > Works fine.
    > just elapsed time ?
    > Right ?
    > Thanks,
    > B.
    Yep it's just a timer really.
    You can go here
    http://yourhome.honeywell.com/Consumer/Cultures/en-US/Products/Thermostats/
    and find a manual for your unit.
    George
    George, Feb 9, 2007
  6. Robert11
    Pete C. Guest
    Robert11 wrote:
    > Hello,
    > thermostats for it.
    > Works fine.
    > just elapsed time ?
    > Right ?
    > Thanks,
    > B.
    Not elapsed time, like every 3 months, but elapsed fan run time so a
    more accurate reflection of the filters expected condition. You'll get a
    longer interval during the "off" seasons with minimal heating and
    cooling. You might even be able to adjust the time setpoint to better
    match the filters you are using and dust conditions. One feature I'd
    like to see is a minimum fan run time function to insure the fan cycles
    for air filtering purposes even if heating or cooling is not required.
    Pete C., Feb 9, 2007
  7. "Pete C." <> wrote in message
    > Robert11 wrote:
    >> Hello,
    >> Honeywell
    >> thermostats for it.
    >> Works fine.
    >> I
    >> just elapsed time ?
    >> Right ?
    >> Thanks,
    >> B.
    If you have that type of thermostat, you can do that. Just set your fan
    setting to CIRC. The fan runs at random intervals about 35% of the time.
    Dimitrios Paskoudniakis, Feb 9, 2007
  8. "Robert11" <> wrote in message
    > Hello,
    > Honeywell
    > thermostats for it.
    > Works fine.
    > I
    > just elapsed time ?
    > Right ?
    > Thanks,
    > B.
    As someone else replied, this is based on elapsed fan run time. You can
    turn this feature off or change the setting:
    Press your System button (Heat, Cool, Off)
    Press the blank center square at the bottom and hold for about 5 seconds
    until the special features menu comes on
    Press the up button through the feature setup (four-digit) numbers until you
    get to number 0500
    It will be set to a number from 0 to 6:
    0 - Off
    1 - 10 fan run time days
    2 - 30
    3 - 60
    4 - 90
    5 - 120
    6 - 365
    To change setup number, press the Up or Down arrow key to the right of 0500
    to change the number between 0 and 6.
    Press Done at bottom left.
    Honeywell assumes 33% average daily use, so 10 fan run time days, on
    average, corresponds to one calendar month. As some have said, during low
    use months this message will come up less often, and during heavy use
    months, more often. If you faithfully change the filter monthly, you might
    as well disable this feature.
    Now if we could only get it to automatically adjust to the new daylight
    savings dates...
  9. Robert11
    Pete C. Guest
    > news:...
    > > Robert11 wrote:
    > >> Hello,
    > >> Honeywell
    > >> thermostats for it.
    > >> Works fine.
    > >> I
    > >> just elapsed time ?
    > >> Right ?
    > >> Thanks,
    > >> B.
    Which thermostats support that feature?
  10. "Pete C." <> wrote in message
    >> news:...
    >> > Robert11 wrote:
    >> >> Hello,
    >> >> Honeywell
    >> >> thermostats for it.
    >> >> Works fine.
    >> >> that
    >> >> I
    >> >> all,
    >> >> just elapsed time ?
    >> >> Right ?
    >> >> Thanks,
    >> >> B.
    >> > a
    Mine is a VisionPro TH-8320U, a 7-day programmable,
    http://customer.honeywell.com/Techlit/pdf/69-0000s/69-1701.pdf.
    My guess is most VisionPro and VisionPro IAQ models have this. The list is
    at
    http://yourhome.honeywell.com/Consu...rammable/Professionally-Installed/Default.htm
  1. Kostas Kavoussanakis
    818
    Nov 3, 2007
  2. Jimbo
    Honeywell Automag Thermostat question
    Jimbo, Oct 20, 2003, in forum: Home Repair
    686
    Tony Hwang
    Oct 22, 2003
  3. tyger1147
    Honeywell Thermostat - EASY question
    tyger1147, Aug 18, 2005, in forum: Home Repair
    361
    Carolina Breeze HVAC
    Aug 20, 2005
  4. JimL
    763
  5. MM
    349
    Man at B&Q
    Nov 23, 2012
