HONEYWELL CENTRAL HEATING VALVE V4043H
Discussion in 'UK DIY' started by tc3man1, Jul 21, 2003.
  1. tc3man1
    tc3man1 Guest
    Can anyone help please.
    The hot water on our central heating system is not working and I have
    tracked the problem back to the micro-switch in the Honeywell valve(it
    was corroded and basically fell apart!). I can find plenty of places
    to replace the whole head but I would prefer to replace just the
    switch. It has a reference number on it of - V94234GJX54. Does
    anybody know where I can buy one - preferably mail order or around the
    London area?
    Thanks in anticipation
  2. tc3man1
    geoff Guest
    In message <>, tc3man1
    <> writes
    >London area?
    It's just a standard microswitch available from most electronics
    suppliers
    geoff
    geoff, Jul 22, 2003
  3. tc3man1
    tc3man1 Guest
    fred <> wrote in message news:<s8LrTGARYEH$>...
    > In article <>,
    > tc3man1 <> writes
    > >London area?
    > It looks like a standard V3 microswitch with button actuator but has small
    > solder terminals. These are ten a penny (well one a quid) from just about
    > anywhere, but generally come with spade terminals which you would have
    > to cut down & solder to.
    > Maplin http://www.maplin.co.uk code GW71N 99p
    > RS http://rswww.com code 159-4534 £1.60 + vat
    > btw, capitals in the subject line won't make you many friends, it's
    > considered SHOUTING and a bit rude . . . . hth
    Thanks for the info - the part's on order! No offence intended re the Caps!
    tc3man1, Jul 22, 2003
  1. Andy Hall
    925
  2. Duncan
    744
    Duncan
    Nov 9, 2005
  3. t
    10
    1,725
    Doctor Drivel
    Apr 3, 2006
  4. Si
    907
    geoff
    Oct 6, 2007
  5. Replies:
    882
