Help! Need to adjust UPVC front door
Discussion in 'Misc DIY' started by Brownie, Aug 24, 2003.
  1. Brownie
    Brownie Guest
    Help! :)
    Stupidly tried to adjust my PVC-U front door and now can't shut it and lock
    it. A contingency plan is in place for overnight, but I was just try to
    adjust it as it seemed to be catching in the hot weather and I guessed it
    expanded slightly. Now, stupidly I have played with all the settings and
    can't get it to shut with out removing one of the frame lock plates.
    How do the hinge side allen keys work? I have three hinges - presumably the
    botton allen key holes move it up and down. There are then three allen key
    holes facing each hinge - presumably lateral movement? Which way turns to
    do what?
    I can get the door shut in the frame but the mechanism won't lock. Is there
    a buikders way of systematically adjusting it all to get it to a proper fit
    again. At the moment it seems to be out in up and down movement and too far
    over to the frame at the top.
    (Look, I've said I was stupid at least twice!)
  2. >Stupidly tried to adjust my PVC-U front door and now can't shut it and lock
    >do what?
    Look here
    http://www.thewindowman.co.uk/toe_heel.htm
    Laurence Payne, Sep 12, 2003
  1. Franklin Bowen
    645
    George E. Cawthon
    Feb 29, 2004
  2. Campbell Murray
    22,256
    Speleo
    Jan 3, 2016
  3. Replies:
    279
  4. Modern Composite Doors
    How To Adjust UPVC Door?
    Modern Composite Doors, Nov 30, 2009, in forum: UK DIY
    811
    David Perry
    Nov 30, 2009
  5. Adjust door latch - help!
    , Sep 24, 2010, in forum: Home Repair
    13
    656
    Stormin Mormon
    Sep 25, 2010
