Hairline cracks
Discussion in 'UK DIY' started by Mike Mitchell, Oct 21, 2003.
  1. I painted the walls four months ago, using Homebase/Dulux Emulsion
    (whatever I hadn't used up). I treated several hairline cracks
    beforehand with flexible filler out of the gun (the kind that is
    overpaintable after about an hour). But because the cracks were really
    hairline ones, I just smeared the filler on with a palette knife,
    forcing it into the crack, then wiped over with a damp sponge.
    Now the cracks have reappeared. What can I use to prevent this from
    happening again? Maybe I *should* have used the gun and really forced
    the gunk into the crack. However, they really ARE hairline ones!
    Cheers!
    MM
  2. Mike Mitchell
    dg Guest
    Use a flexible filler or mastic.
    dg
    "Mike Mitchell" <> wrote in message
    news:eek:...
    > Cheers!
    > MM
    dg, Oct 21, 2003
  3. Mike Mitchell
    David Hearn Guest
    news:eek:...
    Aren't you meant to widen hairline cracks (into a V shape) and then fill
    them. AFAIK, attempting to fill hairline cracks with filler is
    difficult/impossible to do properly.
    David Hearn, Oct 22, 2003
  4. Mike Mitchell
    fred Guest
    In article <>, Mike Mitchell
    <> writes
    I have an old house with lath and plaster ceilings & walls & this is an
    ongoing problem. There are small movements going on all the time which
    mean that cracks just open up again & again. I am just about to try some
    wall repair tape from screwfix:
    http://www.screwfix.com/app/sfd/cat/pro.jsp?id=87018
    It is very thin and has a flexible self adhesive backing with a tissue paper
    like top layer. Haven't tried it yet, but it looks like it will flex enough to
    absorb movement and is paintable.
    fred
    fred, Oct 22, 2003
  1. Mat Dunning
    Hairline cracks - external wall
    Mat Dunning, Sep 30, 2003, in forum: Misc DIY
    4,477
    Mat Dunning
    Oct 1, 2003
  2. Merryterry
    1,177
  3. TomL
    Basement floor hairline cracks
    TomL, Dec 21, 2003, in forum: Misc DIY
    313
  4. blueman
    550
    blueman
    Sep 12, 2005
  5. Replies:
    514
