Gypcrete
Discussion in 'Home Repair' started by franz frippl, Aug 2, 2007.
  1. franz frippl
    franz frippl Guest
    Are there alternatives to Gypcrete brand poured floor?
    What might they be?
    I am working on a 20x24 cabin and wish to pour it myself. Has anyone done
    this as DIY?
  2. franz frippl
    franz frippl Guest
    On Thu, 02 Aug 2007 19:58:06 -0500, Al Bundy wrote:
    > franz frippl <> wrote in
    > news:xyrsi.1823$:
    >> What might they be?
    >> done this as DIY?
    > I'm no concrete guy at all but you want to mix & pour like 18 cu yds of
    > concrete?!!!! More if over 4" thick. Rebar? Cell phone to call 911?
    > How are you getting all this mix to the site is my curiosity.
    18 cu yds?
    The area is 480 sq ft and the pour is 1-1/2". Gypcrete is lighter than
    concrete. I calculated 2 cu yds of material max. Quote for job is $1600
    minimum. Just looking for way to cover radiant floor tubing.
    There must be alternative product out there, I just don't know what it is.
    franz frippl, Aug 3, 2007
  3. franz frippl
    marson Guest
    > >news:xyrsi.1823$:
    > >> What might they be?
    > >> done this as DIY?
    > 18 cu yds?
    I'm shooting from the hip here, and throwing out some ideas. You
    could try calling your local redi mix plant and see if they have
    lightweight concrete. Also regular concrete could be used, if your
    floor structure can support the weight. Depends on your ambition and
    skill level too...1600 doesn't sound that bad really.
    marson, Aug 3, 2007
  4. franz frippl
    RicodJour Guest
    > What might they be?
    > this as DIY?
    http://www.google.com/search?hl=en&q=self-leveling lightweight concrete
    If you do it yourself it's pretty much guaranteed you won't get the
    single smooth surface that you would if you had it pumped in. It's a
    fair bit of work and the materials aren't that cheap. The sixteen
    hundred you mentioned doesn't sound that steep, but I guess it's more
    a question of what you had allowed for the radiant covering.
    RicodJour, Aug 3, 2007
  5. franz frippl
    DanG Guest
    You don't tell what type of radiant floor you are covering.
    If it has to do with ceramic tile, this is the absolute best site
    on the internet
    http://www.johnbridge.com/
    I didn't look very hard because I don't know what you need, but
    here is radiant story from that site:
    <http://www.johnbridge.com/vbulletin/showthread.php?t=36020>
    ______________________________
    Keep the whole world singing . . . .
    DanG (remove the sevens)
    "franz frippl" <> wrote in message
    news:xyrsi.1823$...
    > What might they be?
    > anyone done
    > this as DIY?
    DanG, Aug 4, 2007
  6. franz frippl
    franz frippl Guest
    > on the internet
    It's going to be radiant tubing with ceramic tiles. Thanks for site.
    franz frippl, Aug 6, 2007
  1. cracker
    Ardex on Gypcrete Subfloor
    cracker, Feb 1, 2005, in forum: Misc DIY
    755
    cracker
    Feb 1, 2005
  2. Darro
    Gypcrete floor alternative
    Darro, May 14, 2005, in forum: Misc DIY
    874
    Darro
    May 14, 2005
  3. Darro
    Crack repair - gypcrete floor
    Darro, Jul 23, 2005, in forum: Misc DIY
    695
  4. Darro
    427
    SQLit
    Dec 5, 2005
  5. Replies:
    413
