Glass top (Radiant) Range surface unit replacement
Discussion in 'Home Repair' started by Usenet Poster, Jan 31, 2005.
  1. One of the surface units in my 4.5 year old GE radiant range failed.
    Is it easy to repace by myself, or it is better to call a prefessonal?
    I never worked on any of my ranges before. But I did work on electricity
    before - add circuits, install lights , etc.
    Thanks for the tips, or any references.
  2. Matt
    Matt Guest
    You should be able to do this. Get the model number and post back here
    with it; the 'appliance repair aid' guy will hook ya up.
    Matt, Jan 31, 2005
  3. Appliance Repair Aid, Jan 31, 2005
  4. Jeff and Matt,
    Thanks.
    I'll check the model number tonight when get home.
    One of the elements was dead completely. The indicator will
    come on when it is turned on. But the surface will remain
    cold. This is the front element (large one) that was used
    most often.
    3 other surfaces elements, including the dual coil one, are
    fine.
    Y.
    Appliance Repair Aid wrote:
    > Hi,
    > Model#?
    > http://www.applianceaid.com/model.html
    > Some model# helps.
    >>One of the surface units in my 4.5 year old GE > radiant range­
    > failed
    > Totally dead? Might be the element, switch, wiring between the 2 items.
    > jeff.
  5. Jeff,
    OK. The model No. is JSP40BOWBB GE Profile
    The problem is with the large front element. It stays cold after turn it
    on, even though the indicator LED is on.
    So is replacing a surface element for the glass top DIY'able? If so,
    where can I find the parts?
    Thanks.
    Y.
    > Hi,
    > Model#?
    > Some model# helps.
    > failed
    > jeff.
  6. Usenet Poster wrote:
    > Jeff,
    it
    > Thanks.
    > Y.
    Closest that would come up online...
    JSP40BW1BB JSP40BW2BB JSP40BW3BB JSP40BW4BB Slide in style.
    http://www.repairclinic.com/referral.asp?R=153&N=824239
    Large haliant surface burner with sensor, 2000W
    Appears the perimeter around the glass top has screws to lift the glass
    top to access the elements below....
    http://tinyurl.com/55u85
    Once the top is lifted, prop it up and the elements has bars that go
    across the top holding the elements to the glass top panal.
    Hope something here helps,
    jeff.
    Appliance Repair Aid, Feb 1, 2005
  7. Thanks Jeff.
    How can I tell if that 2000W can really be a replacement of the
    bad burner? What the consequence would be if it is not exact
    match to the existing one? How do I tell the wattage of the bad
    element?
    Y.
    "Appliance Repair Aid" <> wrote in message
    > > Jeff,
    > it
    > > Thanks.
    > > Y.
    > Hi,
    > jeff.
    Usenet Poster, Feb 1, 2005
  8. BTW, The your link of diagram for the GE range looks exactly like mine,
    as far as the layout is concerned.
    Y.
    "Usenet Poster" <> wrote in message
    news:YOCLd.2323$7u1.1277@trnddc02...
    > Thanks Jeff.
    > element?
    > Y.
    > news:...
    > > > Jeff,
    > > it
    > > > Thanks.
    > > > Y.
    > > Hi,
    > > jeff.
  9. Usenet Poster wrote:
    > Thanks Jeff.
    > element?
    > Y.
    > bad burner?
    Double check the model#, but each one I looked up came up the same
    replacement element for the large non-dual element. The wattage rating
    is also/should be writtin on the bottom of the element.
    Might not line up with the markings on the top.
    jeff.
  10. "Appliance Repair Aid" <> wrote in message
    > > Thanks Jeff.
    > > element?
    > > Y.
    > Hi,
    > > bad burner?
    > jeff.
    Jeff,
    Thanks much. You are really helpful.
    Y.
    Usenet Poster, Feb 2, 2005
  1. Stan Brown
    9
    498
    GigaNews
    Feb 29, 2004
  2. edfan
    Change glass top on smoothtop range?
    edfan, Apr 18, 2004, in forum: Home Repair
    352
    edfan
    Apr 28, 2004
  3. RicodJour
    Glass top Range
    RicodJour, Apr 17, 2008, in forum: Home Repair
    8
    337
    Edwin Pawlowski
    Apr 18, 2008
  4. Dick Adams
    Glass-Top Electric Range
    Dick Adams, May 19, 2009, in forum: Misc DIY
    12
    552
    Tony Sivori
    May 19, 2009
  5. DerbyDad03
    14
    342
    DerbyDad03
    Aug 24, 2013
Share This Page
