Getting paint off pipes
Discussion in 'Misc DIY' started by The Medway Handyman, Jul 21, 2008.
  1. Getting paint (usually emulsion) off of copper pipes is a right PITA. Has
    to be done though.
    Ok if you can get a blowlamp involved, but many times you can't. I've tried
    pipe prep tools, those open mesh abrasive strips for plumbers & stainless
    steel scrubby thingys, all work, but too slow.
    Any other methods of shifting it?
    Dave - The Medway Handyman
    www.medwayhandyman.co.uk
  2. The Medway Handyman
    Rod Guest
    > to be done though.
    I have tried all the below - but it does stick rather well, doesn't it?
    Don't think anything actually works better than Nitromors. Except
    replacing the pipe... :)
    Nitromors.
    Sandpaper.
    Scotchbrite pads.
    Scrubbing brush and vim (scouring powder).
    NaOH.
    Wire brush.
    Rod
    Hypothyroidism is a seriously debilitating condition with an insidious
    onset.
    Although common it frequently goes undiagnosed.
    <www.thyromind.info> <www.thyroiduk.org> <www.altsupportthyroid.org>
    Rod, Jul 21, 2008
  3. The Medway Handyman
    Spamlet Guest
    "The Medway Handyman" <> wrote in message
    news:Ep5hk.30732$...
    > to be done though.
    > tried pipe prep tools, those open mesh abrasive strips for plumbers &
    > stainless steel scrubby thingys, all work, but too slow.
    Once upon a time I'd have just said: "It'd be cheaper and quicker to replace
    the pipe." But I suppose that is no longer the case...
    Spamlet, Jul 21, 2008
    >> PITA. Has to be done though.
    >> plumbers & stainless steel scrubby thingys, all work, but too slow.
    > Have a look in Wickes for one of the blue pipe cleaner thingies (cost
    > about a fiver IIRC - looks like a blue cylinder about 40mm diameter
    > and 75mm long). It has a 15mm end and a 22mm one. The inside being
    > lined with a fine steel brush. You shove it over the end of the pipe
    > and turn. One direction is easy - a few turns and it leaves the pipe
    > nice and clean if its just dirty metal. Turn it the other way however
    > and you get a much harsher brush action - that will usually take
    > emulsion off.
    I've got one of those, but its not doing the job - maybe I need to replace
    it.
  5. The Medway Handyman
    RW Guest
    > to be done though.
    Having a similar problem recently I just tapped the paint with the side of a
    file and it chipped off.
    Other than that.............
    .. Angle Grinder ;-)
    RW, Jul 22, 2008
    > message news:Ep5hk.30732$...
    > side of a file and it chipped off.
    > . Angle Grinder ;-)
    I was actually thinking of using my Dremel - does that count as an angle
    grinder?
    The Medway Handyman, Jul 22, 2008
  1. Witchy
    476
    Witchy
    Sep 22, 2003
  2. Craig Graham
    Getting paint off carpet
    Craig Graham, Apr 17, 2004, in forum: Misc DIY
    9
    Craig Graham
    Apr 18, 2004
  3. ben
    474
    andrewpreece
    Jul 9, 2005
  4. Dave
    15
    1,338
    Lobster
    Mar 25, 2007
  5. jogey
    getting paint off taps
    jogey, May 19, 2007, in forum: Misc DIY
    1,157
