Gas Water Heater - Pilot button dosen't pop back up.
Discussion in 'Home Repair' started by mbethers@comcast.net, Nov 12, 2006.
  1. Guest
    My gas water heater started leaking out of the pressure releif valve.
    I replaced the valve, in the process of trying to relight the water
    heater, it will now not light. The pilot button sticks down and you
    have to pull it up to get it to come back up. The manual says call the
    gas company when this happens, which I will do.. But does anyone know
    what causes this?
    Thanks,
    Mike
    , Nov 12, 2006
  2. Guest
    HeyBub wrote:
    > <> wrote in message
    > news:...
    > > what causes this?
    > The gas company has no knowledge or ability to fix your water heater.
    > They'll just shut off your gas.
    > Call the manufacturer.
    If what you're saying is the valve button stays depressed in the
    position where it provides gas to the pilot to light it, then it sounds
    like a problem with the valve assembly. Depending on your skill
    level, replacements are available and you can replace the whole thing
    for a lot less than a service call.
    , Nov 12, 2006
  3. Guest
    wrote:
    > HeyBub wrote:
    > > <> wrote in message
    > > news:...
    > > > what causes this?
    Another thought. What kind of problem was there with the relief valve?
    Was this just a tiny drip, that got worse over time, or a sudden
    bigger one? Reason I ask is if it opened due to over temp, there is
    another final over temp cuttoff in the gas valve itself. And once that
    goes, the valve is kaput. I don't know how it behaves after that, but
    perhaps the symptom you are seeing is it?
    , Nov 12, 2006
  4. Guest
    control valve bad:( its replaceable but if the tank is more than a
    couple years old your better off just replacing the tank, control
    valves are expensive and tank may leak later after valve replacement.
    time for a new tank and its likely the tank overheated and the
    thermostat failed first.
    tanks are cheap parts are expensive
    , Nov 12, 2006
  5. Guest
    , Nov 12, 2006
  1. Al D
    LP gas water heater Pilot
    Al D, Jul 7, 2004, in forum: Home Repair
    289
    m Ransley
    Jul 7, 2004
  2. Brett Miller
    23
    686
    Brett Miller
    Mar 28, 2006
  3. Shaman683
    Fridge clicks but dosen't run...
    Shaman683, Oct 9, 2006, in forum: Misc DIY
    377
    propman
    Oct 9, 2006
  4. Marc O'Brien
    Press a button - any button
    Marc O'Brien, Dec 27, 2003, in forum: HVAC
    385
    Marc O'Brien
    Dec 27, 2003
  5. Replies:
    14
    409
    The Daring Dufas
    Jan 9, 2012
