Gas cost calculator
Discussion in 'UK DIY' started by Mike Mitchell, Jan 6, 2004.
  1. Given two gas meter readings, e.g. 6789 and 6913, what is the formula
    for calculating the cost of the gas used (using typical UK gas price)?
    MM
  2. Mike Mitchell
    Andy Hall Guest
    On Tue, 06 Jan 2004 09:42:47 +0000, Mike Mitchell
    >MM
    Refer to your supplier and ask for their tariff figures or look at
    your last bill. The meter may be measuring in cubic metres or in
    deprecated cubic feet. You can then work out the amount of heat in
    kW.h using the conversion that they give and add in any factors such
    as standing charges. You pay by the kW.h
    Some suppliers charge different prices for the first N kWh
    ..andy
    To email, substitute .nospam with .gl
    Andy Hall, Jan 6, 2004
  3. Mike Mitchell
    Owain Guest
    On the back of the gas bill
    Gas units used
    multiply by imperial to metric conversion factor of 2.83
    multiply by volume conversion factor of 1.022640
    multiply by calorific value of 40.1 (Megajoules per cubic metre)
    divide by kilowatt hour conversion factor of 3.6
    = kilowatt hours used
    124 units
    x 2.83 = 350.92
    x 1.022640 = 356.86
    x 40.1 = 14390.47
    / 3.6 = 3997 kWh
    @ 2.659 p/kWh = GBP106.29
    + VAT of 5% = 5.31
    Note that some of the factors (esp the calorific value) may vary from time
    to time and place to place.
    Owain
    Owain, Jan 7, 2004
  4. On Wed, 7 Jan 2004 15:14:36 -0000, "Owain"
    >Gas units used
    >124 units
    > x 2.83 = 350.92
    > x 1.022640 = 356.86
    > x 40.1 = 14390.47
    > / 3.6 = 3997 kWh
    >+ VAT of 5% = 5.31
    >Owain
    Thanks, Owain!
    MM
    Mike Mitchell, Jan 7, 2004
  1. Dean Richard Benson
    Myson Heatloss Calculator
    Dean Richard Benson, Feb 13, 2004, in forum: UK DIY
    730
    Andy Hall
    Feb 13, 2004
  2. Douglas
    612
    jacob
    May 7, 2004
  3. Dave
    17
    1,469
    Roger
    Jan 10, 2005
  4. Golan
    Calculator For Gas Meter
    Golan, Nov 8, 2006, in forum: UK DIY
    9
    763
    Roger Mills
    Nov 10, 2006
  5. Jack
    13
    861
    clifto
    Jan 25, 2006
