Garage Floor Load
Discussion in 'Building Construction' started by john smith, Feb 12, 2004.
  1. john smith
    john smith Guest
    I am in the process of building 24X22 2 story garage and wondering if anyone
    can provide the live load capacity of the second floor. The building will
    have a full basement under the floor where the cars are parked. Here are the
    particulars:
    2X10 joists on 1 foot centres. Span is 10 Feet.
    6 X 10 beem down the centre with Steel jack posts every 6 feet.
    I would like to be able to park two cars and have a 4" concrete floor
    susspended.
  2. - john smith -
    anyone
    will
    are the
    > particulars:
    > susspended.
    - Nehmo -
    You're doing it backwards. First, you need to determine what loads the
    structure will encounter. Then, you design accordingly.
    * Nehmo Sergheyev *
    Nehmo Sergheyev, Feb 12, 2004
  3. john smith
    john smith Guest
    Sorry, the building will be two stories including the basement. And no
    building is not built just have the foundation poured looking for advice on
    the floor system so that I minimize costs and keep the basement as useable
    as possible.
    "" <> wrote in message
    news:JQPWb.9066$...
    > This will vary with local building codes. Call your code compliance dept.
    > Also, do you mean 2-story with a basement (i.e. another story on top of
    the
    > parking area), or 2 stories including the basement (i.e. cars are parked
    on
    > 2nd story)?
    > Jeff
    > "john smith" <> wrote in message
    > news:sHPWb.94144$...
    > anyone
    will
    > the
    > > particulars:
    > > susspended.
    > > Thanks
  4. john smith
    Bob Morrison Guest
    In article <sHPWb.94144$> john smith
    says...
    Uniform Building Code requires floor live load capacity of 50 psf OR a
    concentrated load of 2000 pounds applied to an area of 20 sq. in.
    located anywhere in the structure.
    Bob Morrison
    R.L. Morrison Engineering Co.
    Structural and Civil Engineering
    Poulsbo WA
    Bob Morrison, Feb 12, 2004
  5. john smith
    Phil Scott Guest
    "Bob Morrison" <> wrote in message
    > says...
    anyone
    The key word there is is *live. that would be a load in excess of the dead
    load due to seismic activity or for instance driving a car in fast and
    stopping hard etc. The floor support needs to be seen by a structural
    engineer imho. or at the very least a state licensed general contractor...
    if you do it without such advice it would be smart to oversize the lumber,
    double up every other stringer, bolt the doubled up stringers together as
    well... block them all well, then secure your metal concrete support decking
    to the stringers with at least 3" long x 5/16" lag bolts with 1" flat
    washers under the heads, every 12" or so.
    The load needs to be figured on a worst case basis...will you or the next
    owner back a 3/4 ton pickup loaded with gravel in there some day? It could
    happen. So that has to be the load along with an assortment of worst case
    gargage cludge.
    In this case a structural engineer could save you some trouble.
    Phil Scott
    > Bob Morrison
    > Poulsbo WA
    Phil Scott, Feb 13, 2004
  6. I would have an engineer design it without using 2X10's to hold the concrete.
    Using 2x10's to hold up concrete is not a good idea.
    2X10's bend and concrete doesn't bend much before it cracks.
    I would use corrugated metal decking to hold up the concrete until it cured.
    JerryD(upstateNY)
    "Phil Scott" <> wrote in message news:c0hi2s$9eu$...
    > says...
    anyone
    gargage cludge.
    Phil Scott
    > Bob Morrison
    > Poulsbo WA
    JerryD\(upstateNY\), Feb 13, 2004
  1. Ian
    Washers - Front Load vs. Top Load
    Ian, Jun 1, 2005, in forum: Home Repair
    23
    719
    Joshua Putnam
    Jun 4, 2005
  2. Replies:
    606
    Jerry
    Dec 13, 2006
  3. Andy Energy
    Standby Load, Plug Load
    Andy Energy, Feb 6, 2008, in forum: Building Construction
    296
    Andy Energy
    Feb 6, 2008
  4. Replies:
    415
    Oscar_Lives
    Oct 17, 2006
  5. UtahBill
    332
    UtahBill
    Jan 25, 2007
