Garage door has difficulty closing
Discussion in 'Misc DIY' started by Steven, Feb 12, 2008.
  1. Steven
    Steven Guest
    My garage door opener can open smoothly, but it only closes about half
    way - seemlingly encounters resistance - and then the door re-opens.
    I disconnected the automatic opening system and tried to close the
    door manually - it worked but I could feel resistance when pulling it
    down around half way. The system seems fine - springs, cables,
    rollers, etc. (I just installed a new SEAS garage door opener two
    weeks ago and it worked fine until two days ago. It's an old door
    abotu 15 years old and the old garage door opener was replaced. I
    also lubricated the components of the garage door system.)
    Any suggestions? Thank you.
  2. Steven
    DerbyDad03 Guest
    Is it significantly colder compared to when you installed the opener?
    My Craftsman has a habit of balking when it gets really cold. I have
    to increase the up and/or down force to get the door to travel it's
    full distance. I should note that my opener is about 20 YO, however,
    it has been doing it since the first cold winter.
    DerbyDad03, Feb 12, 2008
  3. Steven
    Joe Guest
    Keep looking...you missed a roller or two or a track misalignment. Get
    up closer and have someone move the door for you and the fault might
    be more obvious. Good luck.
    Joe
    Joe, Feb 12, 2008
  4. Steven
    Guest
    > Joe
    The resistance is either binding or the springs have too much
    tension. Since it used to work, I'd suspect it's binding. As
    suggested, have someone work the door while you look for where it may
    be binding. Could be anything from the track and rollers to the
    track having moved and the door now hitting the side of the garage.
    , Feb 12, 2008
  5. Steven
    Guest
    On Feb 12, 3:32�pm, wrote:
    > On Tue, 12 Feb 2008 09:24:11 -0800 (PST), Steven <>
    > >I �disconnected the automatic opening system and tried to close the
    > >down around half way. �The system seems fine - springs, cables,
    > >weeks ago and it worked fine until two days ago. �It's an old door
    > >abotu 15 years old and the old garage door opener was replaced. �I
    > >Any suggestions? �Thank you.
    > In addition to the other suggestions take a look at the garage door
    > opener track. If it's a two piece track the connection in the middle
    > may be misaligned and cause a hiccup in the middle.
    whens the last time somone lubed the door tracks rollers etc?
    often its never.........
    , Feb 12, 2008
  6. Steven
    Guest
    On Tue, 12 Feb 2008 12:48:25 -0800 (PST), "" <>
    >> >I ?disconnected the automatic opening system and tried to close the
    >> >down around half way. ?The system seems fine - springs, cables,
    >> >weeks ago and it worked fine until two days ago. ?It's an old door
    >> >abotu 15 years old and the old garage door opener was replaced. ?I
    >> >Any suggestions? ?Thank you.
    It's okay to oil the bearings in the rollers, but putting lube or grease on the
    track or roller surface is usually not helpful. It just attracts grit, and gets
    sticky when cold.
    , Feb 12, 2008
  7. Steven
    Dan Espen Guest
    Steven <> writes:
    Another poster mentioned Sears openers and the cold.
    Mine is a Sears about 2 years old.
    Just today I had to adjust the down force
    otherwise it would start to close then move back up.
    First really cold day of the year.
    Dan Espen, Feb 13, 2008
  1. Linda Boumarafi
    Electric Garage Door Not Closing
    Linda Boumarafi, Jul 3, 2003, in forum: Misc DIY
    876
    Dick Hamlen
    Jul 3, 2003
  2. Henry
    Garage Door Closing and Bright Sun
    Henry, Sep 3, 2004, in forum: Misc DIY
    329
    Henry
    Sep 3, 2004
  3. barry martin
    barry martin, Sep 4, 2004, in forum: Misc DIY
    388
  4. Brigitte
    289
  5. Ken
    427
