For info - building regs on loo/kitchen/fire escape routes
Discussion in 'Misc DIY' started by lyn rivers, Jan 27, 2005.
  1. lyn rivers
    lyn rivers Guest
    Hi all, I've just had a reply from BCO to my query about a loo leading
    off a kitchen, and whether opening up a staircase wall adjoining a
    kitchen affects fire escape routes, and thought it might be of use to
    someone here. This is what he says:
    1. Yes, a toilet can open into a kitchen provided there is a washbasin
    in the toilet.
    2. The removal of a wall would need approval if it is a load bearing
    wall. Also all habitable rooms on the upper storey should have windows
    which allow for escape, having an un obstructed area of at least 0.33m2
    and be at least 450mm high and 450mm wide and the bottom of the
    openable area should be not more than 1100mm above the floor. Similarly
    all ground storey rooms should open directly onto a hall or other
    suitable exit or be provided with windows as before described. I would
    also recommend the provision of smoke detectors within the property.
    I'm assuming from this that it's ok to have stairs leading up from the
    kitchen, provided that all rooms upstairs have windows big enough to
    escape through. Hmmm... time to get planning... <g>
    HTH :)
    Lyn
  2. "lyn rivers" <> wrote in message
    > in the toilet.
    My brother has just built a kitchen extension with stairs in it. The door to
    the garage is under the stairs - fire door with intumescent strip. His
    upstairs windows are an easy fire escape onto grass - one of his dogs has
    leapt out of it on a few occaisions ...
    The rule I'm personally worried about in my case is the one about low
    windows having to be made of toughened glass - the thing that makes them
    excellent fire escapes may be my downfall ....I doubt Pilkington K qualifies
    brugnospamsia, Jan 27, 2005
  1. Steve Firth
    Metal paint for rusty fire escape
    Steve Firth, Aug 14, 2004, in forum: Misc DIY
    20
    2,751
  2. Hugo Nebula
    Re: Steel Staircase / Fire Escape
    Hugo Nebula, Sep 4, 2004, in forum: UK DIY
    1,929
    Hugo Nebula
    Sep 7, 2004
  3. Spike
    10
    1,974
    jim_in_sussex
    Oct 31, 2004
  4. abd08
    Fire Escape Rusting
    abd08, May 9, 2006, in forum: UK DIY
    18
    980
    The Natural Philosopher
    May 10, 2006
  5. John
    Fire Escape Route
    John, Apr 23, 2010, in forum: UK DIY
    10
    630
    Steve Walker
    Apr 25, 2010
