fluctuating water temp on new combi
Discussion in 'UK DIY' started by pauly, Mar 21, 2005.
  1. pauly
    pauly Guest
    Not really a DIY question however this is the most appropriate group i can
    find.
    I just had a new combi boiler fitted to replace an old system with boiler
    and immersion. Problem is the water temperature varies quite a lot -
    sometimes its blazing hot and give it a minute and it goes cold before
    getting too hot again.
    The guy who fitted it is really good (reputation) and am trusting him to
    figure it out however i've got curious as to what it could be.
    What could be the cause?
    fwiw my house is a 3 bed semi 30 years old and no water supply problems that
    i've noticed. New boiler is a Worcester.
    Paul
    pauly, Mar 21, 2005
  2. pauly
    John Guest
    "pauly" <> wrote in message
    > find.
    various things but as a starter can you quote the commissioning figures he
    has filled in for model number, water temperatures, flow rates, gas rate etc
    on your little blue benchmark book that came with the boiler
    John, Mar 21, 2005
  3. pauly
    a Guest
    > find.
    that
    I must say I have found our worcester combi a bit more awkard than having a
    hot water cylinder. I find you cant really have the hot taps on just a
    little as you need a certain flow before the boiler kicks in (so the water
    stays cold), opening it a bit more and the boiler kicks in and the water
    becomes mad hot, only when the tap is open about half way (a ceramic tap) do
    I get a nice hot temperature that doesnt scold my hands! I cant say I have
    had the constant hot-cold-hot... with a constant flow.
    a, Mar 21, 2005
  4. pauly
    Paul Guest
    In news:d1n2ao$l5i$,
    John <> typed:
    > news:...
    >> i can find.
    >> boiler and immersion. Problem is the water temperature varies quite
    >> a lot - sometimes its blazing hot and give it a minute and it goes
    >> cold before getting too hot again.
    >> him to figure it out however i've got curious as to what it could be.
    > figures he has filled in for model number, water temperatures, flow
    > rates, gas rate etc on your little blue benchmark book that came with
    > the boiler
    I haven't seen the book you mention yet. Do you mean figures obtained after
    testing or manufacturer figures for that particular boiler?
    The Model is a Worcester 28i Junior.... is this table any use?
    http://tinyurl.com/3sq4a (its an image on worcester-bosch.co.uk)
    Paul
    Paul, Mar 21, 2005
    group i can
    > > find.
    boiler
    before
    him to
    problems
    > that
    having a
    a
    water
    water
    tap) do
    have
    Which model have you got? You could always turn the DHW temperature
    down on your boiler (assuming it's got one)!
    Mathew J. Newton, Mar 22, 2005
  6. pauly
    a Guest
    > having a
    > a
    > water
    > water
    > tap) do
    > have
    we have the Junior 24i I think. Is there any adjustment possible on the flow
    rate needed to fire up the boiler?
    a, Mar 26, 2005
  1. mike
    Fluctuating mains pressure
    mike, Sep 22, 2005, in forum: UK DIY
    341
  2. Steve S \(another one\)
    Optimum boiler temp and hot water temp
    Steve S \(another one\), Mar 14, 2008, in forum: UK DIY
    15
    591
    Mary Fisher
    Mar 15, 2008
  3. Laughing  Rock
    Fluctuating Water Pressure
    Laughing Rock, May 11, 2005, in forum: Home Repair
    445
    Laughing Rock
    May 14, 2005
  4. David Fraleigh
    unstable, fluctuating house current?
    David Fraleigh, Dec 31, 2005, in forum: Home Repair
    21
    548
    Sheldon Harper
    Jan 2, 2006
  5. Replies:
    13
    906
    DIMwit
    Aug 16, 2007
