floor joist size for 6m span
Discussion in 'Misc DIY' started by zak mondo, May 24, 2004.
  1. zak mondo
    zak mondo Guest
    Hi, I've bought a 500 year old house in croatia that needs 2 new
    floors. The interior measures 6m x 6m. The original joists are really
    small and rotten. What size of joists would I need to have to span the
    room without support posts ? I don't think I will be able to get
    I-beams but could get timber in the following dimensions: 100mm x
    200mm or 140mm x 200mm. Would this be sufficient ? Cheers.
  2. zak mondo
    BigWallop Guest
    "zak mondo" <> wrote in message
    These sites should tell you all about it:
    http://www.diydoctor.org.uk/projects/load-bearing_walls.htm
    http://www.naturalhandyman.com/iip/infxtra/infload.shtm
    http://www.hometips.com/diy.html
    http://www.basecuritysystems.no-ip.com
    Version: 6.0.690 / Virus Database: 451 - Release Date: 22/05/04
    BigWallop, May 24, 2004
  3. zak mondo
    Set Square Guest
    I'm sure that some of the experts will quote chapter and verse from the
    loading tables - but 6 metres seems a hell of a span to do in one go. From
    the top of my head, I reckon you would need something with a vertical
    dimension considerably in excess of 200mm.
    Are you *sure * you can't get an I-section RSJ? With a 200mm high RSJ across
    the middle of the room, you could cut 200x50 joists into it - so the RSJ
    would be within the ceiling depth and would be hidden. The joist span would
    then only be 3 metres - which is fine.
    Cheers,
    Set Square
    ______
    Please reply to newsgroup. Reply address is Black Hole!
    Set Square, May 24, 2004
  4. zak mondo
    John Rumm Guest
    It depends on what you would consider to be an allowable maximum
    deflection for the floor. In the UK you are limited by building regs to
    about 0.003 * the length of the beam (or 14mm for beams over ~5m IIRC).
    Assuming there is no Croatian BCO standing over your shoulder and you
    can tollerate say 30mm deflection then you have a much simpler task.
    I would have thought that 140x200 would do a credible job at that length
    even if they did not reach UK standards for deflection.
    The other possibility is a flitch beam - that would need a metal plate
    down the middle and wood either side all bolted together - but that may
    be more accessable than a full on I beam.
    Cheers,
    John.
    | Internode Ltd - http://www.internode.co.uk |
    | John Rumm - john(at)internode(dot)co(dot)uk |
    John Rumm, May 24, 2004
  1. zak mondo
    joist size to span 20ft
    zak mondo, May 24, 2004, in forum: Home Repair
    1,321
    big jim
    May 25, 2004
  2. PT Baker
    Ceiling joist span
    PT Baker, Feb 21, 2004, in forum: Building Construction
    587
    Eric Ryder
    Feb 21, 2004
  3. Bubba Bean
    Deck Joist Span Length?
    Bubba Bean, Sep 14, 2004, in forum: Building Construction
    960
  4. Charlie
    I-joist span
    Charlie, Oct 1, 2004, in forum: Building Construction
    26
    1,389
    Charlie
    Oct 6, 2004
  5. John
    joist span calculation formula?
    John, May 25, 2005, in forum: Building Construction
    3,193
    Roarmeister
    May 27, 2005
