Fixing Kingspan or Celotex to wall. How?
Discussion in 'Misc DIY' started by Clive, Dec 29, 2007.
  1. Clive
    Clive Guest
    Do I just
    1. fix (screw) horizontal wood batttens to the wall, at a distance
    equal to the width of a Kingspan / Celotex panel
    2. Push the panel between the battens so held by friction
    3. Fix vertical wood battens to points on the horizontal battens
    4. Fix the plywood or tiling board to the vertical battens
    5. Tile wall
    Clive
    Clive, Dec 29, 2007
  2. Clive
    Lobster Guest
    Clive wrote:
    > Do I just
    > 5. Tile wall
    IMO it depends what sort of wall you're attaching it to, and what you're
    trying to achieve.
    If it's a brick wall, then really you'll want an air gap between the
    brick and the insulation, best achieved by building a studwork frame an
    inch away from the wall, and having the kingspan held within that by
    friction.
    David
    Lobster, Dec 29, 2007
  3. Re: Fixing Kingspan or Celotex to wall. How?
    On Dec 29, 7:10 pm, Lobster <> wrote:
    > Clive wrote:
    > > Do I just
    > > 5. Tile wall
    > trying to achieve.
    > friction.
    There is a fine netting that is made to cover the partition and hold
    the foam in situ. Or you could just tack a couple or three 1 1/2"
    ovals front and back. Fiddly for a large wall.
    I suppose you could just run a couple of strands of fishing line for
    each row front and back. Actually you don't need anything on the face
    as thaty will be covered with board.
    Weatherlawyer, Dec 29, 2007
  4. Re: Fixing Kingspan or Celotex to wall. How?
    On Sat, 29 Dec 2007 11:45:34 -0800 (PST), Weatherlawyer
    >> Clive wrote:
    >> > Do I just
    There are a lot of .pdfs 'hidden' in the depths of the celotex site:
    sorry I don't have the URL, but dig around and you will find the info -
    you can also google for solutions.
    But: wouldn't cavity wall insulation be a) nearly as cheap* but more
    importantly b) save you 50 or more mm of valuable intenrnal space on
    each external wall? Is it worth doing for LESS than 50/60mm insulation
    (plus board on top?)
    *assuming this is a large project
    no spam here, thanks, Dec 29, 2007
  5. Re: Fixing Kingspan or Celotex to wall. How?
    Assuming there is a cavity to insulate our walls a solid stone/rubble
    infill. The house I was born and brought up in had 9" solid brick walls.
    > Is it worth doing for LESS than 50/60mm insulation (plus board on top?)
    Celotex/kingspan is a very good insulator. I lined the end wall of a small
    bedroom here, took two two sheets of 25mm foam bonded to 18mm plaster
    board. The difference it made to the room is amazing.
    Cheers
    Dave. pam is missing e-mail
    Dave Liquorice, Dec 29, 2007
  6. Clive wrote:
    > Do I just
    So far not bad, though vertical is preferred..and use 2x2 STUDS,. not
    flimsy battens..
    No, you use the celotex foil tape to seal and hold them up
    To the studs. We've just eliminated the battens..
    > 5. Tile wall
    If you want..
    The Natural Philosopher, Dec 30, 2007
  7. Lobster wrote:
    > Clive wrote:
    >> Do I just
    >> 5. Tile wall
    > trying to achieve.
    > friction.
    Totally unnecessary.
    Slap the celotex hard up against it.
    No vapour can get in if you seal it, and if it comes in from outside, it
    can get out to the outside again ..
    > David
  8. Re: Fixing Kingspan or Celotex to wall. How?
    >>> Clive wrote:
    >>>> Do I just
    Assuming it is IS a cavity wall.
  9. Clive
    Lobster Guest
    The Natural Philosopher wrote:
    > Lobster wrote:
    >> Clive wrote:
    >>> Do I just
    >>> 5. Tile wall
    >> you're trying to achieve.
    >> an inch away from the wall, and having the kingspan held within that
    >> by friction.
    I'm sure the airgap is stipulated on Kingspan's site; certainly when I
    did a conversion job recently which included insulating a single-skin
    external brick wall, Building Control were adamant that there should be one.
    David
    Lobster, Dec 30, 2007
    >> Lobster wrote:
    >>> Clive wrote:
    >>>> Do I just
    >>>> 5. Tile wall
    >>> by friction.
    >> it can get out to the outside again ..
    > one.
    That's probably to make sure the woood studwork stays dry,BCO ijnsited I
    ventilate my solid block and beam suspended concrete floor too. I guess
    they were worried the concrete might rot.
    I never got a satisfactory explanation.
    > David
  11. Clive
    Mike Clarke Guest
    [snip]
    > one.
    I don't know about Kingspan but Celotex advise fixing it straight against
    the wall in the "Insulation solutions for solid masonry walls" leaflet
    available from their downloads page
    <http://www.celotex.co.uk/downloads.php>.
    Mike Clarke
    Mike Clarke, Dec 30, 2007
    #11
  1. Tim S
    2,365
    tom patton
    Apr 13, 2004
  2. Dean Heighington
    Where to buy Celotex/Kingspan/Alternative
    Dean Heighington, Oct 25, 2004, in forum: UK DIY
    13
    1,317
    Andy Hall
    Nov 7, 2004
  3. sm_jamieson
    kingspan/celotex under concrete slab
    sm_jamieson, Jul 25, 2008, in forum: Misc DIY
    618
    Lobster
    Jul 26, 2008
  4. SlicK the original
    Kingspan, Celotex or ????
    SlicK the original, Feb 4, 2004, in forum: UK Home Improvement
    355
    SlicK the original
    Feb 4, 2004
  5. David Robinson
    8
    1,566
    js.b1
    Nov 12, 2010
