fitting new shower mixer, bar type
Discussion in 'UK DIY' started by Tom, May 8, 2011.
  1. Tom
    Tom Guest
    Hi All,
    I have just bought a Swirl thermostatic shower mixer that is to
    replace a leaking AquaLisa recessed model.
    After I have filled in the hole where the old shower was (it was
    sunken into the tiled plywood "wall" of a cupboard) I need to fit the
    new mixer.
    The method of fixing it isn't clear from the manual - it seems to be
    achieved using "s-elbows" (supplied) and nothing else. Is this usual?
    Is there a guide anywhere of how to fit these type of mixers? Is it
    effectively supported on the pipes - it does seem quite heavy?
    What do I connect the s-elbows to at the supply side?
    Thanks, Tom
    Tom, May 8, 2011
  2. Roger Mills
    Roger Mills Guest
    On 08/05/2011 17:43, Tom wrote:
    > Hi All,
    > new mixer.
    > Thanks, Tom
    When I fitted mine, in a stud wall, I used one of these:
    http://www.screwfix.com/p/grohe-exposed-installation-kit/51167
    The elbows are rigidly supported by the cross-piece which, in turn, I
    screwed to the studding. I used Hep2O (or equivalent - forget exactly
    which) flexible plastic pipe - with inserts, of course - straight into
    the compression inputs of the elbows.
    I was building the wall at the same time, so it was easy to build this
    into the wall. If you can get behind your plywood 'wall', and fit one of
    these, it will make your life a hell of a lot easier.
    Cheers,
    Roger
    ____________
    Please reply to Newsgroup. Whilst email address is valid, it is seldom
    checked.
    Roger Mills, May 8, 2011
  3. YAPH
    YAPH Guest
    A few suggested fixing methods on the DIY wiki
    John Stumbles -- http://yaph.co.uk
    Eagles may soar, but weasels don't get sucked into jet engines.
    YAPH, May 8, 2011
  4. sm_jamieson
    sm_jamieson Guest
    On May 8, 5:43 pm, Tom <> wrote:
    > Hi All,
    > new mixer.
    > Thanks, Tom
    When I did mine, it came with non-cranked 1/2 to 3/4 inch adapters and
    some panel-mounting bolts. I connected the adapters to a compression
    elbow at the back, then mounted the adapters onto a piece of aluminium
    plate (from a local metal supermarkets) carefully measured and
    drilled. The larger plate gives a more solid fixing, and better to
    resists forces is someone uses it as a grab handle !
    Forward planning is required to ensure the correct depth after tiling.
    Simon.
    sm_jamieson, May 9, 2011
  5. In article <>,
    Tom <> writes:
    > Hi All,
    The bar type are all (AFAIK) slow acting thermostats using
    a phile.
    Your recessed one may have been a fast acting one designed
    for a multipoint heater or combi boiler (although they also
    come in cheaper slow acting versions for stored hot water,
    and completely non-thermostatic valves).
    Might want to double check you have a suitable replacement before
    fitting it - there are several types of thermostatic controls
    for different situations (with a wide range of prices).
    Andrew Gabriel
    [email address is not usable -- followup in the newsgroup]
    Andrew Gabriel, May 14, 2011
  1. Mr Blue Skye
    1,801
    Dane Koekoek
    Jan 19, 2004
  2. John Miller
    Fitting a shower bar mixer
    John Miller, Aug 22, 2004, in forum: Misc DIY
    10
    1,723
    John Miller
    Aug 31, 2004
  3. Mr Blue Skye
    Mira 415 shower mixer unit or any Mira shower mixer unit
    Mr Blue Skye, Jan 8, 2004, in forum: UK Home Improvement
    517
    Alistair Dore
    Jan 9, 2004
  4. Keefiedee
    464
  5. David WE Roberts
    Fixing a bar type mixer in a solid wall
    David WE Roberts, Jul 10, 2012, in forum: UK DIY
    266
