Fitting a Wylex Consumer unit with spur to shed
Discussion in 'UK DIY' started by thiery@ntlworld.com, Dec 9, 2003.
  1. Guest
    I am looking to replace my consumer unit with a split load Wylex 12
    way Consumer unit, since i have run out of ways on my exisiting
    consumer unit. At the same time I want to run a spur to a shed for a
    small ring main and lights. The shed will have my old consumer unit
    (Which has a 63A/30mA Incomer providing RCD and Isolator
    functionality)
    Is it acceptable/possible to connect the spur to the shed via an RCBO,
    or a second dual pole isolator or should I just use a standard MCB?
    Also what rating would be suitable for running a spur to a shed, would
    a 16A MCB/RCBO be suitable? (Internaly I was going to use 2.5mm t&e
    ring main cable, while externaly I was going to use 2.5mm armoured
    t&e)
    My worries are that if there are problems on the external wiring for
    any reason, then there are safety issues by just connecting it via a
    standard MCB?
    As a slightly seperate point does anyone know if it possible to add a
    second RCD to a wylex unit, so as to provide aditional seperate RCD
    protection for the lighting circuits from the ring mains?
    , Dec 9, 2003
  2. BillR Guest
    > functionality)
    Exactly what I have..
    I just used an mcb so the cable to my detached garage is protected.
    > t&e)
    Should be fine, you could use a higher rated mcb if you required more power
    in the shed.
    I put my ext supply on a 16A mcb on the non-RCD side
    I guess it could depend on how your ext cable is run. Mine is buried under a
    concrete path and so I'm unlikely to hit with a garden tool.
    > standard MCB?
    Why? Its unusual to RCD protect lighting circuits these days..
    Presumably because its very difficult to get a shock from fixed light
    fittings unless you try really hard :)
    You don't have to work on them live because with their mcb(s) off you can
    provide light from a power circuit.
    It should be possible but you may have to cut the provided busbar. Note RCDs
    are 2 mcb widths and the Wylex prebuilt kit only has 2 separate spare mcb
    positions, so it wouldn't fit anyway without rebuilding the kit in a
    different way.
    Note if you want to get an extra mcb for the Wylex and you want it to use
    their busbar, then be sure the new mcb is also Wylex brand.
    BillR, Dec 9, 2003
  1. Kalico
    Volex or Wylex consumer unit
    Kalico, Dec 5, 2003, in forum: UK DIY
    18
    1,574
    BillR
    Dec 6, 2003
  2. andrewpreece
    Wylex or Volex Consumer units?
    andrewpreece, Dec 30, 2004, in forum: UK DIY
    958
  3. T i m
    Spur + spur from ring?
    T i m, Aug 27, 2005, in forum: UK DIY
    487
    T i m
    Aug 28, 2005
  4. Michael Chare
    31
    1,726
    Doctor Drivel
    Jan 3, 2006
  5. Replies:
    395
