Fitting a socket for electric fire
Discussion in 'UK DIY' started by D.M.Chapman, Jan 23, 2010.
  1. D.M.Chapman
    D.M.Chapman Guest
    Got a fireplace being installed in a few weeks (limestone thing - SWMBO
    has sorted it) so I've now got the job of sorting out power for the
    electric fire that will be fitted in it...
    Fire comes with a normal 13A plug - and obviously don't want a wire
    trailing around the front so I was thinking of spurring form the socket
    that is on the outside of the chimney breast and going straight through
    the wall to a socket *inside* the old fireplace.
    That would be neat, and fairly easy. I was thinking of running it from a
    switch fused spur next to the existing sockets, through the chimney and
    straight into the back of a new unswitched socket - possibly an external
    rated one to be sure (something like http://preview.tinyurl.com/mk-socket
    inside the fireplace).
    Only reason to use something a bit better than a normal socket is that it's a
    bit dusty in there - nothing major (it's been open for over a year while I
    hunted for a round tuit and the front room hasn't filled with dust :)).
    Does this plan sound ok? Any better ideas? I could fit a cable outlet
    instead of a socket I guess but then I'd have to chop off the plug which
    I'd rather not do if poss.
    Given the fire just stands in the hole it's not as if the socket will be
    inaccessable.
    Cheers,
    Darren
  2. "D.M.Chapman" <dmc@puffin.> wrote in message news:hjf87d$bp8$...
    > inaccessable.
    > Cheers,
    > Darren
    Instead of drilling a hole in the wall to take a lead to a spur which is next to
    existing sockets why not just fit a longer lead on the fire, run the lead through
    the hole you've drilled in the wall and fit a plug on it afterwards ?
    michael adams
    michael adams, Jan 23, 2010
  3. Bill
    Bill Guest
    In message <>, michael adams
    <> writes
    >is next to
    >lead through
    >michael adams
    When I did mine I had the fused spur on the outside of the fireplace and
    ran the lead from the fire into the back of it through a hole in the
    brickwork. No need then for anything extra in the fireplace. No wires
    visible at all.
    Bill
    Bill, Jan 23, 2010
  4. Owain
    Owain Guest
    Is the fire actually ever going to be switched on?
    Otherwise sounds reasonable to me.
    Owain
    Owain, Jan 23, 2010
  5. cynic
    cynic Guest
    > rated one to be sure (something likehttp://preview.tinyurl.com/mk-socket
    > inaccessable.
    > Cheers,
    > Darren
    Sounds perfectly reasonable and your choice of socket will ensure no
    problems from sparging or water coming down the chimney under extreme
    conditions.
    Do check your earth loop continuity after installing wont you
    cynic, Jan 23, 2010
  6. Lobster
    Lobster Guest
    > <> writes
    >> is next to
    >> lead through
    > visible at all.
    Just wot I did. Easier (and cheaper TBH) than a waterproof socket
    inside the fireplace. (Got tested as part of the whole house inspection
    by an electrician and passed no problems)
    David
    Lobster, Jan 24, 2010
  7. D.M.Chapman
    D.M.Chapman Guest
    In article <w%M6n.30809$>,
    Good good. I'll probably go with the socket in the fireplace anyway as
    a) I've already got a spare MK external socket and b) I'm not sure the
    cable on the fire would be long enough (if I've got to add an extension
    to the cable I may as well used fixed wiring for it).
    Cheers all,
    Darren
    D.M.Chapman, Jan 24, 2010
  1. neil leslie
    1,030
    Terry D
    Aug 27, 2004
  2. Farouq
    676
  3. Lobster
    Fitting a weatherproof 13A socket
    Lobster, May 5, 2008, in forum: Misc DIY
    10
    554
    Lobster
    May 10, 2008
  4. Marvin
    629
    Marvin
    Jun 3, 2007
  5. misterroy
    16
    719
Share This Page
