fireproof wall for behind my wood stove
Discussion in 'Building Construction' started by john, carmel, ny, Nov 15, 2010.
  1. Hi All,
    Recently I had the perimeter of my house dug out and replaced with gravel
    and drainage pipe, Afterwards I tore down the basement walls to
    cinderblock to check for mold / rotted wood, mouse damage… you name it!
    I am now ready to rebuild my walls. My question is…. I have a Quadra fire
    wood stove in a downstairs corner, and I am considering a nonflammable
    wall product for around the stove area instead of drywall and heat
    shields… Can I use brick or stone directly on the cinderblock? What is the
    best way to attach it to the existing cinderblock wall? Do I need to put
    anything on the cement slab floor under the brick / stone? Are there
    products you recommend?
    Thanks in advance for any advice you can share....,
    John
  2. john, carmel, ny
    PeterD Guest
    On Mon, 15 Nov 2010 18:39:09 +0000,
    (john, carmel, ny) wrote:
    >Hi All,
    >John
    Fireresistant sheetrock. Walls up to eight ft from the edge of the
    stove. Ceiling should be further if possible.
    PeterD, Nov 15, 2010
  3. john, carmel, ny
    AndyS Guest
    > >Hi All,
    > >shields… Can I use brick or stone directly on the cinderblock? What isthe
    > >John
    Andy comments:
    You might consider durock, the cement version of sheet rock, which
    is
    used normally for floors that will have tile put on them.... Perhaps
    it
    can be fastened to the cinder block with liquid nails, and a half
    dozen cement anchors at strategic places.....
    If this works, it will be simple to tile it over......and nothing
    there
    to burn....
    Andy in Eureka, Texas
    AndyS, Nov 20, 2010
  4. john, carmel, ny
    Guest
    > > >Hi All,
    > > >I am now ready to rebuild my walls. My question is…. I have a Quadrafire
    > > >John
    > Andy comments:
    > is
    > it
    > there
    > to burn....
    >                  Andy in Eureka, Texas- Hide quoted text -
    > - Show quoted text -
    There is no reason to put anything over the blocks if you want to
    install tiles or brick. I would want to be sure that you use a
    thinset type of tile cement rather than mastic just un case. The big
    thing is to keep the fire inside the stove.
    , Nov 25, 2010
  5. john, carmel, ny
    PeterD Guest
    On Fri, 26 Nov 2010 18:35:15 -0600, Steve Barker
    <> wrote:
    >these stove are not near as dangerous as people would have us to
    >believe. I've got a freestanding stove and there is a styrofoam chicken
    >incubator about 18 inches from it. It's still in it's original form. I
    >put a sheet of galvanized sheet metal on the wall next to it, because it
    >thought it would perhaps keep some heat off the wall, well the sheet
    >steel is still cool to the touch. 18" away also.
    That is the attitude that gets houses burned down. Complacency,
    failure to undertand the hazards of the heating system, and
    (potentially) misuse of the unit.
    The sheet metal doesn't get hot because it reflects radiant heat back
    into the room, not because there is no heat there.
    I suspect that wood stoves result in more house fires than any other
    single cause in areas where they are used.
    PeterD, Nov 27, 2010
  6. john, carmel, ny
    hebinwi Guest
    http://tech.groups.yahoo.com/group/woodheat/ Is the greatest resource
    for information you need. The moderators are wood burners with many
    years experience and write a blog with tons of info that you can
    consult as well. My guess is there is probably a local code that will
    have to be adhered to, and most certainly clear your project with the
    insurance company to make sure you don't step on their toes.
    hebinwi, Nov 28, 2010
  1. keng
    1,076
    Simon Langford
    Jan 20, 2005
  2. The Natural Philosopher
    Re: Heatproofing the wall behind wood burning stove
    The Natural Philosopher, Jan 20, 2005, in forum: Misc DIY
    963
  3. Pete C
    779
  4. lyn rivers
    952
    lyn rivers
    Jan 22, 2005
  5. bdeditch
    1,612
    Italian Mason
    Sep 3, 2006
