Fireproof board
Discussion in 'Misc DIY' started by Maart, Jan 7, 2005.
  1. Maart
    Maart Guest
    Hi, I am going to fit a woodburning stove into my fireplace in the next few
    days but I am having a few problems finding some fireproof board. The shop
    where I bought it has said that it is easy to find in any diy shop such as
    b&q but he didn't know the name of it. The board has to go around the flue
    up inside the chimney to stop any draught coming back down. Does anyone know
    of a suitable product? Any help will be appreciated. Thanks
    Maart, Jan 7, 2005
  2. BigWallop
    BigWallop Guest
    "Maart" <> wrote in message
    news:crmu91$ol0$...
    A metal lining on the old fire damper shelf will be just as good. A scrap piece
    of 1/8'' plate with a hole through it will also act as good draw damper for and
    old chimney flue. What's the reason for lining the old fire place anyway. Or
    is this a new built flue?
    BigWallop, Jan 7, 2005
  3. Carl Morris
    Carl Morris Guest
    This company are excellent, http://www.woodstoves.co.uk/skamol.htm
    Tydraig
    news:crmu91$ol0$...
    > few days but I am having a few problems finding some fireproof board. The
    > shop where I bought it has said that it is easy to find in any diy shop
    > such as b&q but he didn't know the name of it. The board has to go around
    > the flue up inside the chimney to stop any draught coming back down. Does
    > anyone know of a suitable product? Any help will be appreciated. Thanks
    Carl Morris, Jan 7, 2005
  4. Maart
    Maart Guest
    Thanks for the replies. The stove has a 1m flue pipe that comes out of the
    top, this will be the only bit of flue pipe, sorry if I misled you
    BigWallop. All I need is the part that seals the chimney aroung the flue
    pipe. After the recomendation of the shop owner I thought that some type of
    fireboard would be easier to work with.
    Tydraig, thanks for the link. I will see what they have to offer.
    "BigWallop" <spam.guard@_spam_guard.com> wrote in message
    news:IsDDd.5604$...
    > news:crmu91$ol0$...
    >> few
    >> shop
    >> as
    >> flue
    >> know
    > piece
    > for and
    > Or
    Maart, Jan 7, 2005
  5. BigWallop
    BigWallop Guest
    news:crn4ol$501$...
    Ah ha !!! With you now. A piece of metal will ideal for this situation, and it
    doesn't need to be a huge thick thing. A collar made of sheet metal used in
    ducting systems is the ideal choice, as it's rust proof and easy to work.
    A piece of sheet metal cut to the size of the throat of the smoke box and sealed
    around with fire clay is what you need. Cut a hole through it to take the end
    of the flue pipe you have, and seal that round with fire clay as well. Sheet
    metal is easily cut with a decent set of tin sheers, so it's really a simple and
    cheap job do make a suitable collar for yourself.
    The most expensive part of the project will most likely be the fire clay, but
    you'll need to use that on any thing you fit inside the chimney anyway. An off
    cut from a scrappy that keeps old ducting material is the cheapest part, I would
    think. So the job should balance itself out on costs of parts.
    Have you also checked to see if the chimney needs a top cover to stop the wet
    weather getting in?
  6. Maart
    Maart Guest
    Thanks for your help Bigwallop. I already have a job lot of fire cement from
    screwfix so I am sorted there. I also know a local scrap metal dealer just a
    few miles from here. It seems like it will be quite an easy job. Thanks
    again.
    Maart
    news:jXEDd.5652$...
    > news:crn4ol$501$...
    >> the
    >> of
    > and it
    > in
    > sealed
    > end
    > Sheet
    > simple and
    > but
    > An off
    > would
    > wet
    > weather getting in?
    Maart, Jan 8, 2005
  1. gillian
    fireproof varnish
    gillian, Apr 7, 2004, in forum: Misc DIY
    9
    1,761
    nightjar
    Apr 8, 2004
  2. Dave Jennings
    Fireproof paint for doors - smallest amount?
    Dave Jennings, Nov 15, 2004, in forum: Misc DIY
    462
    Dave Jennings
    Nov 15, 2004
  3. Brad Jeavons
    12
    2,324
  4. Stephen Gower
    Fireproof rawlplug
    Stephen Gower, Nov 18, 2004, in forum: Misc DIY
    8
    1,054
    The Natural Philosopher
    Nov 19, 2004
  5. Vortex7
    8
    480
    Vortex7
    Oct 6, 2010
