Fire Escape Rusting
Discussion in 'UK DIY' started by abd08, May 9, 2006.
  1. abd08
    abd08 Guest
    Hi All,
    We had our fire escape newly installed about a year ago, and it is
    already starting to rust in places. This doesn't seem normal to me, and
    I don't think the company has done the work properly.
    What do you think I need to check physically on the fire escape, such
    that I can basically tell the guy "you should have done X,Y,Z, this
    isn't good enough etc etc", and so he doesn't try and fob me off with
    "oh, didn't you know you have to repaint these every year" or similar
    Cheers!!
    Raj
    abd08, May 9, 2006
  2. abd08 wrote:
    > Hi All,
    > and I don't think the company has done the work properly.
    > Cheers!!
    > Raj
    Outside iron does have to be painted every year...take a look at the forth
    bridge. ;-)
    Sir Benjamin Middlethwaite
    The3rd Earl Of Derby, May 9, 2006
  3. abd08
    Guest
    Is it galvanised or painted?
    Is it bolted together or welded?
    Can you tell exactly where the rust originates? The bolts/welds, on
    treads on ground or wall attachment points?
    Was it supplied fully finished or primer only?
    , May 9, 2006
  4. abd08 wrote:
    > Hi All,
    It may well be normal.
    I think you do have to repaint every year.
    You might want to go over it and remove all old paint and use a chromate
    type primer on it though. It may be that it wasnt given a decent set of
    primer in the first place.
    > Cheers!!
    > Raj
    The Natural Philosopher, May 9, 2006
  5. abd08
    Guest
    , May 9, 2006
  6. abd08
    Guest
    The3rd Earl Of Derby wrote:
    > abd08 wrote:
    > > Hi All,
    > > Cheers!!
    > > Raj
    > bridge. ;-)
    Urban Myth
    MBQ
    , May 9, 2006
    >> abd08 wrote:
    >>> Hi All,
    >>> such that I can basically tell the guy "you should have done X,Y,Z,
    >>> this isn't good enough etc etc", and so he doesn't try and fob me
    >>> off with "oh, didn't you know you have to repaint these every year"
    >>> or similar
    >>> Cheers!!
    >>> Raj
    >> forth bridge. ;-)
    > Urban Myth
    > MBQ
    Do ya reckon?
    Paint will blister (more so on iron) from the suns heat which will then be
    enough for rain(water)to penetrate below the surface and find its way onto
    the steel,this will then start lifting the paint more heavily as time
    progresses.
    Hence why maintenance of the outside of a property has to be maintained
    where and when its needed every year to keep it in good condition.
    I'll stick with my opinion,thanks
  8. abd08
    Bookworm Guest
    Wrong! Please read the posting by Brian Sharrock. He is quite right. I
    once worked for the company that supplies that system and, providing
    prep is meticulas, 20 years in a salt laden atmosphere is quite normal.
    Thats why North Sea Oil Rigs aren't painted with Dulux.
    Bookworm, May 9, 2006
  9. Pet @ www.gymratz.co.uk ;¬) wrote:
    > On a thread hijack......
    > what would you (or anyone else) recommend for the best stuff to paint
    > a non-galvanised, rusting, outside steel balcony with then Bookworm. ?
    > Ours is suffering badly where the previous owners used to bodge it up
    > with normal gloss paint once in a while.
    > and... :¬) what would be the best method of preperation to halt
    > existing rust?
    For painting iron/steel exterior items I've always used "Hammerite" paint.
    As for halting rust...hmmm! thats a case of how bad its got a hold? for
    surface rust I used a bottle of stuff from a car accesory shop, wasn't
    cheap and came in a quarter of a pint plastic bottle,for the life of me I
    cant remember the name but it contained a chemical that nuetralised the
    rust with a protective finish for painting over.
  10. abd08
    Guy King Guest
    The message <FE%7g.66655$>
    from "The3rd Earl Of Derby" <> contains these words:
    > bridge. ;-)
    Or galvanised. Might be well worth it!
    Skipweasel
    Pay no attention to that man behind the curtain.
    Guy King, May 9, 2006
  11. abd08
    Guy King Guest
    The message <Et48g.66816$>
    from "Pet_@_www.gymratz.co.uk_;¬)" <> contains these
    words:
    > what would you (or anyone else) recommend for the best stuff to paint a
    I'd be tempted to take it off and get it galvanised.
    Skipweasel
    #11
  12. abd08
    Andy Dingley Guest
    On Tue, 09 May 2006 13:15:16 +0100, The Natural Philosopher <>
    Where are you going to even _find_ a chromate primer these days ? Apart
    from being horribly toxic, they're also far from the best choice for
    steel.
    A fire escape ought to have been galvanised to begin with. If it wasn't,
    then it needs a good coat of zinc-based primer (Davids 182, or some
    others) onto clean bare metal.
    Andy Dingley, May 9, 2006
    #12
    > existing rust?
    > I am thinking a compressed air "needle gun" for initial attack of paint
    > & rust flakes.
    > 'tis a job for this summer.
    Chromate primer, or zinc primer.
    Ive had best success with stuff like 'jenolite' which IIRC turns iron
    oxide into iron chromate - a tougher proposition by half..then maybe a
    zinc loaded primer to pseudo galvanize.
    Ideally you would then use something like a tow pack epoxy paint al la
    marine (yacht) paint..
    Cleaning is simply down to getting everything loose off. - wire
    brush,sandblasting, Nitromors etc.
    The Natural Philosopher, May 10, 2006
    #13
    > steel.
    I was thinking of anti-rust treatments like Jenolite
    Not so good if its already corroded.
    Agreed galvanisation is the best starting point, but f its been drilled
    or welded or assembles with non galvanised bolts, or non steel ones...
    To those who think that Hammerite works, think again. Utter rubbish the
    one time I tried it.
    #14
  15. abd08
    Bookworm Guest
    Chris Bacon wrote:
    > Wire cup brush on 9" angle grinder. Use a knotted cup brush to get rid
    > of heavy deposits.
    Just polishes the rust. Gritblast to SA2.5 is only way to remove rust.
    Bookworm, May 10, 2006
    #15
    > Iron phosphate, isn't it?
    Ah.. you may well be right, in which case I have been talking bollocks..
    #16
  17. abd08
    Andy Dingley Guest
    Phosphides and tannates. At least you get tannates if you use the good
    stuff (usually white) rather than Jenolite or plain phosphoric acid.
    Not bad as a preparation of existing rust you can't remove, but it has
    limited resistance to rusting in the future. In particular it doesn't
    have the electrolytic protection that zinc coating (plate or paint)
    offers.
    Chromates are useful for aluminium (the yellow-green stuff) but they're
    horribly toxic.
    Andy Dingley, May 10, 2006
    #17
  18. abd08
    Andy Dingley Guest
    >> of heavy deposits.
    A wire brush on an angle grinder is a lot more effective than a slower
    one on a drill. But use a good quality knotted brush, a thick apron and
    a faceshield (not just goggles) or you get peppered.
    Grit blasting is certainly the best, and the only practical way to get
    into the corners - but a portable rig is messy and far from cheap to
    hire. Even a larger "hobby" compressor would struggle with this sort of
    work too.
    #18
    > offers.
    > horribly toxic.
    I've used jenolite FIRST to stabilise the rust, then a zinc primer.
    #19
  1. Steve Firth
    Metal paint for rusty fire escape
    Steve Firth, Aug 14, 2004, in forum: Misc DIY
    20
    2,746
  2. Hugo Nebula
    Re: Steel Staircase / Fire Escape
    Hugo Nebula, Sep 4, 2004, in forum: UK DIY
    1,929
    Hugo Nebula
    Sep 7, 2004
  3. lyn rivers
    1,060
    brugnospamsia
    Jan 27, 2005
  4. Farouq
    725
  5. John
    Fire Escape Route
    John, Apr 23, 2010, in forum: UK DIY
    10
    630
    Steve Walker
    Apr 25, 2010
