Finding beams in garage ceiling?
Discussion in 'UK DIY' started by paulfoel, Mar 24, 2011.
  1. paulfoel
    paulfoel Guest
    Want to hang a bike rack....
    Whats best way to find out where the beams are underneath the artexed
    ceiling. Apart from the obvious of guessing by seeing how hollow it
    sounds when i hit it with a broom handle and then drilling a hole.
    Are the beams likely to run across the garage or up/down?
    BTW- theres a bedroom above the garage if that makes any difference....
  2. paulfoel
    Roger Mills Guest
    Which way do the bedroom floorboards run? The joists will be at right
    angles to these - and you can tell where they are from the rows of
    nails. With a bit of careful measuring you can then work out where the
    joists are relative to the garage ceiling.
    Cheers,
    Roger
    ____________
    Please reply to Newsgroup. Whilst email address is valid, it is seldom
    checked.
    Roger Mills, Mar 24, 2011
  3. paulfoel
    Tabby Guest
    Just tap it with your knuckles, run back and forth over it and you'll
    work it out. Spacing is usually 16", sometimes 2'.
    NT
    Tabby, Mar 25, 2011
  4. paulfoel
    OG Guest
    Have they skimmed the garage ceiling ? Very posh!
    On mine you can see the lines of nails/pins holding the plasterboard to
    the beams.
    And, for what it's worth, they run across the width of the garage.
    OG, Mar 25, 2011
  5. paulfoel
    Lobster Guest
    More likely to be across the width, but can't guarantee it.
    If knocking doesn't work, and presumably you haven't got a stud detector
    or you wouldn't be asking the question, the esiest was would be just to
    drill test holes with your smallest drill to locate the beam - after all
    it's a *garage* ceiling, not your living room; and it's got Artex on
    which will conceal the holes (which could be completely hidden by
    bunging a bit of filler in).
    David
    Lobster, Mar 25, 2011
  1. Grunff
    I beams for shed roof
    Grunff, Jul 31, 2003, in forum: Misc DIY
    566
    Steve
    Jul 31, 2003
  2. Dennis Jenders
    Help Finding Electrical Box in Ceiling
    Dennis Jenders, Jul 29, 2003, in forum: Misc DIY
    945
    volts500
    Aug 6, 2003
  3. Steve Portigal
    removing plant hooks from ceiling beams?
    Steve Portigal, Aug 15, 2004, in forum: Home Repair
    317
  4. Replies:
    17
    521
    xrongor
    May 5, 2005
  5. Ivan Vegvary
    Ceiling joist location help, (stud finding)
    Ivan Vegvary, Aug 28, 2011, in forum: Home Repair
    14
    526
    bob haller
    Aug 29, 2011
