Filling holes in external wall (+tiling on floorboards)
Discussion in 'Misc DIY' started by Sam, Mar 6, 2007.
  1. Sam
    Sam Guest
    Folks,
    Before I start I am NOT a DIY genius, so I will probably say a lot of stupid
    things......
    I am getting my bathroom changed at the minute - it's a bit of a nightmare
    and so far quite a few things have gone wrong :'(... Anyhow one of the
    things I now need to know is how to block up two reasonably large holes in
    an external wall (maybe about 5cm diameter on inside - probably bit bigger
    on outside) - these used to take waste pipes, which have now moved. I can
    look through the holes - you see the internal wall, the insulation (fibre
    type stuff), the external wall and then the outside world.
    Basically I want to know what is the best way to block up these holes. On
    the inside it just needs to be left flat enough to tile over (may be getting
    a plasterer anyway so he can probably sort the flat bit out)... On the
    outside the house is made of block and rendered so think that should be
    easier than a nice brick house.
    I have used that expanding foam stuff before, but not sure how that would
    work here because of the cavity between the two walls..... also if I used
    this how should I finish it off on the outside of the house?
    A sneaky second question on a different topic.........
    We will be having the bathroom floor tiled. There are floorboards down, and
    I was told to lay plywood. The tiler said 1/4 inch plywood would do. A
    joiner who was looking at the doors (unrelated I know) advised at least 3/8
    inch. Unfortunately I hadn't got the plywood before my plumber started
    putting stuff in and he kindly laid plywood - unfortunately it is only 1/8
    inch..... I take it this useless and I would be best taking it up and
    starting again with something thicker (which then means the waste pipe for
    the sink will need to be changed).
    OK sorry for being so thick but any sensible answers from gurus would be
    welcomed.
    Cheers,
    Sam
    Sam, Mar 6, 2007
  2. Sam
    Robert Guest
    I pass on question 1.
    The reason for using ply before tiling on floors is
    a) To provide a smooth surface
    b) To add rigidity to the floor.
    c) In case the subfloor doesn't like wet tile adhesive (chipboard).
    Normally houses have a subfloor (like thick floorboards or chipboard) and then
    the floor above it. For carpets you can just use underlay and go for it, but
    tiles are fussier (being rigid) and need more support. Hence the recommendation
    is to use 12mm ply fixed securely on top of the subfloor. The 3mm ply solves the
    smoothing problem and possibly the moisture problem, but does very little for
    the rigidity.
    I used 9mm on my last bathroom (at the choice of the joiner), and this seemed
    fine. If I were you I would have a look at the floor and make a call on whether
    you think that there is going to be enough movement to crack the grout. If there
    is, take up the ply and lay 12mm. If not, leave the 3mm and go for the tiles.
    I always like to put sinks and bogs on top of the tiles in any case so it might
    not be a bad thing to lift the sink etc until the tiles are in in any case.
    Sam wrote:
    > Folks,
    > things......
    > welcomed.
    > Cheers,
    > Sam
    Robert, Mar 6, 2007
  3. Sam
    malc Guest
    Sam wrote:
    > Folks,
    > stupid things......
    > nightmare and so far quite a few things have gone wrong :'(... Anyhow
    > one of the things I now need to know is how to block up two
    > reasonably large holes in an external wall (maybe about 5cm diameter
    > on inside - probably bit bigger on outside) - these used to take
    > waste pipes, which have now moved. I can look through the holes -
    > you see the internal wall, the insulation (fibre type stuff), the
    > holes. On the inside it just needs to be left flat enough to tile
    > over (may be getting a plasterer anyway so he can probably sort the
    > flat bit out)... On the outside the house is made of block and
    > rendered so think that should be easier than a nice brick house.
    > would work here because of the cavity between the two walls..... also
    > if I used this how should I finish it off on the outside of the house?
    I'd get some cement, ready mix stuff in a bucket from B&Q will do, and
    fill in the holes with that. Try not to let it drop down the cavity
    though in case it bridges the cavity and causes a damp problem. Little
    and often is probably the best way. That will work for the outside wall
    and something similar for the inside wall but maybe polyfiller or
    plaster rather than cement.
    Malc
    "Bother!" said Pooh, and hid Piglet's corpse
    http://farcanal.biz/
    malc, Mar 6, 2007
  4. Sam
    BigWallop Guest
    "Sam" <Sam@does_not_work.com> wrote in message
    : Folks,
    : Before I start I am NOT a DIY genius, so I will probably say a lot of
    stupid
    : things......
    : I am getting my bathroom changed at the minute - it's a bit of a nightmare
    : and so far quite a few things have gone wrong :'(... Anyhow one of the
    : things I now need to know is how to block up two reasonably large holes in
    : an external wall (maybe about 5cm diameter on inside - probably bit bigger
    : on outside) - these used to take waste pipes, which have now moved. I can
    : look through the holes - you see the internal wall, the insulation (fibre
    : type stuff), the external wall and then the outside world.
    : Basically I want to know what is the best way to block up these holes. On
    : the inside it just needs to be left flat enough to tile over (may be
    getting
    : a plasterer anyway so he can probably sort the flat bit out)... On the
    : outside the house is made of block and rendered so think that should be
    : easier than a nice brick house.
    : I have used that expanding foam stuff before, but not sure how that would
    : work here because of the cavity between the two walls..... also if I used
    : this how should I finish it off on the outside of the house?
    It's best if you can fill the holes with a block of some sort, like a bit of
    the original blockwork or a bit ordinary brick, and wedge it in tight in the
    holes, using a mallet or hammer and wood block, to make it rigid so they
    don't fall out. Cut off any protruding bits until the face is slightly
    under the level of the outside block facing. Fill any gaps with a mortar
    mix, a simple two sand to one of cement mix will do, and smooth off to the
    under level of the render.
    Depending on what render you have, you can then mix a batch of the coloured
    adhesive cement and chip, pebble dash, as required. You may even get away
    with a rough sand and cement render and paint it the same colour, if the
    holes are the sizes you say.
    The inner wall is a case of filling the holes with an off-cut of
    plasterboard, if you have or can find some, and glue them in place with
    either PVA Wood Glue, the waterproof stuff is best, or a mix of plaster,
    polyfilla Etc.
    Try not to join anything between the outer skin and inner skin of the wall.
    Any bridging of the cavity can cause dampness from the outside to get in to
    the inner skin, and vice versa.
    : A sneaky second question on a different topic.........
    : We will be having the bathroom floor tiled. There are floorboards down,
    and
    : I was told to lay plywood. The tiler said 1/4 inch plywood would do. A
    : joiner who was looking at the doors (unrelated I know) advised at least
    3/8
    : inch. Unfortunately I hadn't got the plywood before my plumber started
    : putting stuff in and he kindly laid plywood - unfortunately it is only 1/8
    : inch..... I take it this useless and I would be best taking it up and
    : starting again with something thicker (which then means the waste pipe for
    : the sink will need to be changed).
    : OK sorry for being so thick but any sensible answers from gurus would be
    : welcomed.
    : Cheers,
    : Sam
    Tiling on floors needs a solid, unmoving base. If your floors are modern
    chipboard construction, then they don't always like moisture and can belly
    or may split, especially around the edges. Untreated Plywood has a good
    absorbent surface for adhesives, but it is also a good idea, in fact I
    believe it's a must, to give the Plywood a coating or two of diluted PVA
    Glue to give your adhesives an even better grip to the surface.
    Make sure the Ply is thick enough to feel rigid under bare feet. Any
    movement is going to show when you lay tiles and they will start to peel off
    if the floor moves. The Ply needs to be fixed at least every 10 square
    inches (250 mm) with screw nails, not hammer in wire nails, as these pull
    back out with the expansion and contraction of the floor. To keep the Ply
    from bubbling up in different temperature conditions, you really need to use
    screw nails.
    Once you have fixed and primed, the PVA Glue trick, your Plywood, then you
    can begin to dress your tiles. This is just a dry layout of the tiling as
    it is going to be finished. This lets you see where the cuts are going to
    be and if you have any tricky bits that need to be sawn around Etc.
    Use a good proprietary brand of powder adhesive that is mixed with water
    on-site. You'll find that ready mixed tubs will dry to quickly, even under
    cold damp conditions, and crack even before you lay the first tile. I fell
    for that one once, never again. Don't use a grout and adhesive mix either,
    as the grout needs to be drier than the adhesive and the adhesive needs to
    be wetter than the grout and the two do not go together.
    So also use a grout that is mixed with water on-site, as the ready mixed
    types are not worth the tub they are poured from.
    Good luck with it. I hope you enjoy your first bath in your new bathroom.
    BigWallop, Mar 7, 2007
  5. Sam
    Roberts Guest
    "BigWallop" <spam.guard@_spam_guard.com> wrote in message
    news:JBrHh.14470$...
    > off
    > use
    > screw nails.
    > under
    > fell
    > either,
    >Hi Group
    Nice to see Big Wallop back again. You have been missed
    Alan
    Roberts, Mar 7, 2007
  1. Suz
    309
    Dave Liquorice
    Oct 28, 2004
  2. Mark
    8
    562
    raden
    Apr 23, 2006
  3. Replies:
    1,144
  4. cat
    Holes in external wall
    cat, Jun 30, 2003, in forum: Misc DIY
    Peter Scott
    Jun 30, 2003
  5. toopanga
    External Insulation to an external archway
    toopanga, Dec 10, 2010, in forum: Roofing and Guttering
    1,017
    toopanga
    Dec 10, 2010
